There are some circuits that are grounded through the starter blushes. If the bike fell hard, I could see there being some internal disruption there. It is not that hard to pull the starter motor and remove the end cap to inspect the brushes and clean the commutator with some brake cleaner spray. This is the first place I would look.
While you are at it, it would be a good idea to clean the ground connections. There are two of them, one near the shift lever on the intermediate case, and one on the side of the frame backbone up under the fuel tank. Polish the terminals and the ground point with a bit of wet or dry abrasive paper and put a LIGHT coat of dielectric grease or petroleum jelly on everything. Bad grounds can cause all sorts of strange electrical headaches. Good to eliminate them as a problem as soon as possible in the troubleshooting process.
