Author Topic: Rain under the gas door  (Read 3901 times)
Offline F14CRAZY
« on: October 25, 2015, 01:56:28 PM »
This has been going on for a while and I know it isn't exactly a good thing.
After being in the rain or washing I'll find water to be sitting in the space between the rubber gasket under the gas door and the little spring loaded door. Why is rain getting in here? I figured that the little hole underneath on the left is supposed to drain water before it gets down there. I had the tank off earlier while diagnosing my driving lights and I shot some brake cleaner down that hole and it's clear.
There a way to fix this?
  • Grand Rapids, MI
  • '87 K75C
Re: Rain under the gas door
« Reply #1 on: October 25, 2015, 02:02:33 PM »
Are you sure it's not getting there through/around the key lock assy? I have heard of this happening.
There is a repair gasket set available.
part # 16 11 9 062 461  for under $35.
Offline F14CRAZY
« Reply #2 on: October 25, 2015, 02:15:55 PM »
Perhaps that's what I need. I'll check into that this week
  • Grand Rapids, MI
  • '87 K75C
Offline Inge K.
« Reply #3 on: October 25, 2015, 02:35:08 PM »
Also check that the drain isn't blocked, ....small hole on the left side of the filler cap.
  • Norway
« Reply #4 on: October 25, 2015, 08:37:33 PM »
Also, sometimes the hinged lid has been installed backwards and the drain hole doesn't line up with the drain tube.
Offline F14CRAZY
« Reply #5 on: October 25, 2015, 08:55:34 PM »
I noticed that in another thread but my drain lines up
  • Grand Rapids, MI
  • '87 K75C
