Author Topic: Why is there a hole in the top of air flow meter box?  (Read 3614 times)
Offline Barrieb
  • I just keep coming back to Bricks!
« on: October 11, 2015, 04:50:24 PM »
Guys, did my water pump (replaced from spare engine) all good and thought it would a very good idea to check a number of other things out. Such as air filter, on taking out the filter/meter box there are the 2 small flat Allen screw bolts holding the meter, but nearer the large pipe feeding air towards the engine on a sloping part of the box is a hole about 10 mm going into the box and then a gap and then what looks like could be a screw hole into the meter?
Typically no drawings or mention of this in the Haynes manual, is it on purpose? To me it looks like air would get in without going through the filter, has a grommet or screw fallen out any - grateful for any ideas
Barrie
  • East Anglia UK
  • 1987 BMW K100LT a Golden Oldie
Marge: Its easy to critisize
Homer: Fun too!
Re: Why is there a hole in the top of air flow meter box?
« Reply #1 on: October 11, 2015, 05:26:52 PM »
I can only guess with out a picture, as I haven't owned an older 2V K-bike.
If I was to guess, I'd bet it is the adjustment pot for setting the exhaust CO2 mixture.
As in #5, should be a blank filler there. Part #13 72 1 460 802  "blind plug"
« Reply #2 on: October 12, 2015, 11:45:46 AM »
The Lieberry Card Catalog is your friend:
http://www.motobrick.com/index.php/topic,692.0.html
Offline Barrieb
« Reply #3 on: October 12, 2015, 04:55:24 PM »
Thanks guys,
Had a feeling it was a bit dodgy, will source a plug before installing new filter and running again
Barrie
  • East Anglia UK
Homer: Fun too!
