Author Topic: K100 Project for sell.  (Read 4660 times)
Offline PiotrK100
« on: October 05, 2015, 10:40:43 AM »
5500 EUR
op quality project:
- engine perfect new main seal, clutch, water/oil pump, valve clearance, alternator, new injectors, all glass blasted, works like a charm, best graphite oil inside
- powder coating: frame wheels, fuel tank cap, radiator front
- rear sets from english BSK Speedworks
- brake lines steel coated (embroided)
- front brake disc new
- tires new
- rear shaft main seal NEW, all greased with Staburags
- new accessories speedo with warning lights
- KOSO temp sensor and display
- wheel bearings new
- rollgas and grips, brake fluid reservoir,  RIZOMA
- handlebar gears switched for JAP system professionally from Hayabusa
- led turn signals front/rear stop light
- new custom seat with embroidery
- custom exhaust from stainless steel, end pipe BMW 1000S
- almost all nuts, bolts changed for stainless
- many other changes that are visible on pictures
- painting: white pearl.
That was my project for my own use, so did from the best quality stuff and no replacements just originals. In case you want more pictures (66 available) or the movie please contact me. Also you can find HD movie with fully fuctionable K 100 on my facebook: https://www.facebook.com/piotr.synowiec.946
  • Poland
Re: K100 Project for sell.
« Reply #1 on: October 05, 2015, 11:17:28 AM »
greetings piotrk100...
if that thing was in the usa i would fly out and ride it home... then i would return it to oem stock...
