Author Topic: Turn signals/ flashers  (Read 3447 times)
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
« on: September 30, 2015, 01:48:21 AM »
Turn signals and flashers quit working on the way home. I was stopped in a construction zone with the flashers on for about 1o min. Next thing I know none of it works. Fuse is good. What should I check next?
Al
  • Waldport, Oregon
Offline jay1622
Re: Turn signals/ flashers
« Reply #1 on: September 30, 2015, 07:33:41 AM »
I wrote a similar response just last night. Read the first reply on this thread and hopefully it will help you out. Your bike and year are different though.
http://www.motobrick.com/index.php/topic,7450.0.html
  • Charlotte
« Reply #2 on: September 30, 2015, 07:46:16 AM »
The flasher/turn signal module is fed from 2 fuses....check them both.
#3 direct battery power, and #7 switched ignition power.
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
« Reply #3 on: September 30, 2015, 03:34:35 PM »
Big "Thanks" to you Scott. I checked the #7 fuse and it was blown. I'd never would had thought the two were related. You saved me a ton of work, I was ready to pull the tank and start checking grounds, etc.
Thanks Again !!!!!!!
Al
  • Waldport, Oregon
