Author Topic: WTB Panels and maybe a seat? for K75 std  (Read 4825 times)
Trebor
« on: September 23, 2015, 08:18:53 PM »
  :mm Trying to spruce up my '95 K75, std. I'm the second owner since about 2001 and the bike came with a Corbin low seat and of course no side panels. I'd like to add panels which means the Corbin has got to go. But as I am uninformed can someone tell me what seat options I must have? My Clymer indicates that my options are limited as my tool box is not empty but has electronics inside.?  :dunno Bike is being repainted so color of panels doesn't matter.
Re: WTB Panels and maybe a seat? for K75 std
« Reply #1 on: September 23, 2015, 10:49:15 PM »
best bet is to offer a trade with someone who wants a low seat.  http://marketplace.ibmwr.org/ gets pretty good traffic.
Offline whiteout
« Reply #2 on: September 26, 2015, 03:08:26 PM »
You might want to check a parts source like realOEM or MaxBMW. I believe they changed something about the seat mounting on the last few years of the K75. I have a Corbin on my K75S with the side panels that go with the fairing. Mounts the same as the stock seat. I keep tools in the tray over the battery since there isn't much room in the rear with the anti-lock computer. Plus I'd rather have the weight in the center of the bike. Body parts show up on ebay regularly. Good luck.
john
  • Cleveland 44114
  • 2004 K1200RS, 1992 K75S
john
Offline Elipten
« Reply #3 on: September 28, 2015, 10:53:16 PM »
There is a fair bit of hardware difference to mount a normal seat versus a low seat.  It call be found on the parts fiche on line.  PM me if you need help
  • San Antonio, TX
  • 1990 K75RT
Offline smith913
« Reply #4 on: October 29, 2015, 04:20:44 PM »
I have a good shape k100 seat I'm not using. It's OEM.
Alex
  • Alexandria, VA
  • 1985 K100RT
Offline Gio
« Reply #5 on: October 29, 2015, 05:55:24 PM »
Welcome trebor ... re your question of the emptiness of the tool tray (I just went through the transition from std to low seat on my K75s) - the std or "high" seat  config (aka dual bench I believe) has both side panels and space for a tool-tray as part of the "brain box" ... wheras the low seat alternative (approx. 2'' lower) dispenses with the side panels (in lieu of a spacer at the rear of the tank)and has no tool tray above the brain box.
So your first question is to the seat height - if you want to re-install side panels then bear in mind that the std seat will be significantly higher than what you currently have ... personally I found this a little too high for my in-seam and prefer the low seat option - hence the change (although I do miss the tool tray!)
Hope this helps.
Gio
  • NS, Canada
  • K75s ("Buttercup")
Halifax, NS
1994 K75s (UK spec)
1984 Honda 200ES (Big Red)
« Reply #6 on: October 29, 2015, 06:46:06 PM »
greetings trebor...
look here...
