Hey Fellow Brick Flyers,
Got an issue that just came up and am looking for suggestions as to where to start looking.
The Problem-
Today on way to get the bike inspected, it started acting up. The symptoms were:
-Tach falls to zero
-Bike acts like it is running on only 2 cylinders.
-Bike would do this for a 1/2 to 1 mile and then the tach would come back on.
-Then would run normal for a mile or so and then repeat.
The Bike:
1991 K100RS 4 valve
Has Motronic 2.1
Over 77,000 miles on Odometer
*Things of note:
-Bike seemed a little "surgy" today
-While acting up the turnsignals, headlight, brake light, speedometer and gear indicator all worked normally.
(Not sure about cluster illumination lights because it was to bright. Looked like they were on when passed under shade.)
-Bike acts like it has mild vaccum leak...when bike is hot and I shut throttle to brake from highway speed/rpm it sometimes tries to stall/die. (Am planning on tackling this soon).
-Bike has 2,500 miles till next service.
-Bike lives under bike cover outside in Texas(when not being ridden).
Recent history:
-New Fuel pump 1,500 miles back (same time as paint job).
-I rebuilt the starter about 500 miles back. Reassembled correctly, only concern is that I didn't tighten the starter casing screws tight enough. (Did finger tight with screw driver then backed off just a hair)
Mods:
-LED dash lights and additional LED rear markers, LED headlight and Rigid light bar.(Total amp usage ended up being same to just less than stock.
-Remus exhaust
My gut first instinct is maybe time to put fresh thermal paste on ignition amplifier but would like a good list of things to check before I start shooting in the dark.
Btw, she passed inspection. :yes :2thumbup:
Input appreciated,
Freelancer
