Author Topic: Acewell 2803.. almost working perfect =/  (Read 3787 times)
Offline ChristSFP
« on: September 13, 2015, 03:29:34 PM »
So I did the forum search and found some magic help along the way, the K1100rs has some other colors than the K100 but I figured it out.. I think...
The only issue I have now.. and It is quite big.. Everything works, but only when I pull the clutch?? Any takers on my issue?
RPM work flawless, both turnsignals.. headlight.. etc.. Itīs all good =) But Without the clutch pulled, the dash just goes dark and back to "clock mode" where only time is showed.
Cheers
  • Sweden
  • K1100RS
At the moment in my garage..
BMW K1100RS - 1994
Harley Davidson Nightrain - 2007
and before this.. I had maaany other motorcycles ;)
Re: Acewell 2803.. almost working perfect =/
« Reply #1 on: September 13, 2015, 04:09:00 PM »
I'll Guess you have mixed the green/black and the black/green wires...........
The black/green Connects the clutch switch/GPI/starter switch together.
The green/black is the power feed to the instrument (and other this and that).
Offline ChristSFP
« Reply #2 on: September 13, 2015, 04:23:43 PM »
Thanks for your reply, seems highly likly since I don't have green/black only black/green and two green.. :/ I took a chance and I guess they should be switched.
Will try first thing tomorrow.
  • Sweden
  • K1100RS
BMW K1100RS - 1994
« Reply #3 on: September 13, 2015, 05:37:53 PM »
From your description in the first post, you have mixed the two wires in contact 5 & 6 in the first pic.
The green wire was green/black on the earlier two valve models, so I did mix up things a bit too.
« Reply #4 on: September 13, 2015, 05:39:28 PM »
In your 1st picture, Terminal #5 will be the starter interlock output, #6(green) will be the +12v into the cluster, the other green in the 2nd picture terminal #16 is return from the motronic for the tachometer.
Offline ChristSFP
« Reply #5 on: September 14, 2015, 10:46:56 AM »
Thanks! The switch made the difference, now everything works as expected =)
  • Sweden
  • K1100RS
BMW K1100RS - 1994
