Author Topic: Removing Fuel tank - Fuel will not stop  (Read 4021 times)
tony101
« on: September 12, 2015, 09:47:57 AM »
Hi, well i have started to properly investigate my non starting problem ( so far i have found that i have got power at connection 2 an 3 of the Jetronic loom - idle switch) so am trying to remove the tank - a simple task one might think! - so i have done everything that the Haynes manual says (including sucking the pressure out the system) but when i disconnect the fuel pipe form the injector rail fuel comes out and does not stop (well thats not true it might eventually stop, but after half a litre came out i decided that something was not right!). So my question is how do i stop fuel coming out the tank? i thought as it was a pumped system no fuel should come out. Any ideas anyone?
Thanks Tony
Re: Removing Fuel tank - Fuel will not stop
« Reply #1 on: September 12, 2015, 10:42:54 AM »
What's the level of fuel in your tank?
Your symptom might be pointing to a broken fuel filter or split / disconnected hose inside the tank.  Have you peered inside?
BTW, you're right.  When you disconnect the hose from the fuel rail, only a dribble of fuel should come out.
« Reply #2 on: September 12, 2015, 04:04:24 PM »
This might help -- at least to get your tank off so you can drain and inspect it.
http://www.motobrick.com/index.php/topic,6200.msg41288.html#msg41288
