If you're talking about the clutch pushrod, on the K75 it comes out from the front, not the back. You have to remove the transmission completely from the bell housing to access the pushrod. Since this is a later model bike, the thrust bearing (what you call the pressure piston) is a single piece so there should not be a circlip to remove after it has been withdrawn.
Since the pushrod withdraws from the front, it is not necessary to remove it prior to removing the transmission, to inspect and lubricate the clutch splines.
