Hi all. Spent a bunch of time reading the forums about clutches and shifting, but haven't found my exact issue. New to me K100RS was having some stiff and reluctant downshifting. A little rev on the throttle, or shifting right after clutching was managing it. Then, the shift lever broke (still not quite sure how), and I rode it home with the broken lever hose clamped together. :yow
Fast forward to lever and clutch cable replacement...lever fits, clutch adjusted according to forum instructions and Clymer manual. But won't go into first without MAJOR effort. Just sounded and felt like like grinding.
Finally figured out that if I screw in the adjustment bolt at the back of transmission in further, the bike shifts in to gear without issue. BUT...is that ok to do? :dunno2: Screwing the bolt in and adding pre-loaded pressure on the clutch has moved the friction point in the lever WAY up...meaning the clutch doesn't engage until the clutch level is almost all the way out. This is the opposite of what it did before the lever/cable replacement.
I really like 1st gear (though starting in 2nd seems to work fine, too). I've been told to throw the cure-all, clutch spline lube at it, but I want to know if that's the likely fix, or is something else going on? Also, am I risking damage to the clutch riding it like this, even though it works? Thanks!
