Author Topic: why are this one rear wheel bolt colored  (Read 3949 times)
Offline jensk
« on: August 29, 2015, 08:39:07 AM »
I had the rear wheel of to do a FD spline lube today. I discovered that one of the wheel bolts are colored.
Is there a reason for just one of the wheel bolts are colored green?
  • Copenhagen, Denmark
  • '93 K75RT
Past: Honda CB550K3, Honda CB550F, Matchless G80 and a couple of MZ's
Re: why are this one rear wheel bolt colored
« Reply #1 on: August 29, 2015, 08:46:36 AM »
the green one goes in the middle hole... looks like you are missing a non painted bolt and the spacer for the center bolt...
Offline Inge K.
« Reply #2 on: August 29, 2015, 09:13:57 AM »
The center bolt you find on paralever models, it's not used on monolevers.
If you look around you find a green dot on more bolt heads, whichs says they are checked
with a torque wrench before leaving the assembly line.
It's the same bolts that should be checked at specified intervals according to the maintance schedule.
  • Norway
« Reply #3 on: August 29, 2015, 09:31:01 AM »
 :hehehe
Offline jensk
« Reply #4 on: August 29, 2015, 10:50:51 AM »
Thank you for the reply. Can't find any green spots on the other three bolts. Anyhow it doesn't matter since i torqued them to the specified Nm's
  • '93 K75RT
« Reply #5 on: August 29, 2015, 01:41:43 PM »
You will most likely find the green dots/paint on other bolts around the bike... rear shock mount's, fork triple tree bolts, etc.... you get the idea.
