Author Topic: Eliminating fuel level float  (Read 6406 times)
Offline TrueAce
« on: August 28, 2015, 11:07:26 AM »
 Putting together a K100 scrambler, and decided to junk the factory gauges. Why keep the fuel level float if there is no fuel level light...........unless the lack of that sensor would affect the engine management unit. Can anybody testify as to the consequences of simply not installing the fuel level float?
  • Florida
Re: Eliminating fuel level float
« Reply #1 on: August 28, 2015, 05:46:05 PM »
None. Only real wiring needed to the fuel tank would be power and ground for fuel pump.
« Reply #2 on: August 28, 2015, 07:13:36 PM »
If you haven't removed the BMW instruments yet I'd suggest taping over the Low Fuel light for a while and see how you like living without it.
« Reply #3 on: August 28, 2015, 07:28:50 PM »
It's an integral part of the dynamic K-kinetic fuel stabilizing system.  Resistance of the float keeps the gas from sloshing around.  Removing it may void your warranty!
Offline TrueAce
« Reply #4 on: August 28, 2015, 07:38:59 PM »
Ha! Or is it "LOL.....LMAO" these days. I have so much history riding bikes which had NO fuel display......you look in the tank, right? After all , this is a " scrambler", heavy as a GS, but in the spirit that less is more, I am gonna leave out the floppy as I rebuild the the fuel delivery.
  • Florida
« Reply #5 on: August 28, 2015, 08:36:02 PM »
It's doable, as Scott says.  You'll loose low fuel indication though.  You might get all your money back by selling the old fuel level sender on Ebay.
« Reply #6 on: August 28, 2015, 10:42:22 PM »
good point.  Seems most tanks are missing caps, pumps and senders.  But isn't the sender attached to the bottom cap, which you'll still need to keep gas in the tank?
« Reply #7 on: August 29, 2015, 02:35:44 PM »
He'll have to manufacture a new base plate with a fuel tight passthrough for the pump wiring.
