Author Topic: K100 aftermarket warning lights  (Read 3341 times)
peely1
« on: August 26, 2015, 05:08:43 PM »
Hi there.
This is my first post. :clap:  Im busy doing a 1985 k100rs into a cafe racer. ive completed most of the project but im now stuck on the warning lights which im installing. Ive bought a set called Highsiders there are indicator lights which i have working. high beam is working but i cant seem to get the neutral light or the oil light working??? tried everything. as soon as i plug the original instruments in it works fine. if anyone could help it would be much appreciated. I will include the instructions from the warning lights :2thumbup:
black (ground) + orange (+) = indicator left
black (ground) + blue (+) = indicator right
black (ground) + yellow (+) = high beam
if neutral light or oil pressure is negative signal:- connect grey to neutral signal and brown to 12v (+) connect green to oil signal and purple to 12v (+)
If neutral or oil pressure is possitive signal connect brown to neutral signal and grey to ground(-) connect purple to oil signal and green to ground (-)
so in all there is grey green purple orange brown black blue and yellow
Thanks in advance.
Michael
