Author Topic: 1985 K100 Vacuum Leak  (Read 5683 times)
Offline smith913
« on: August 17, 2015, 01:33:21 PM »
Hey brickers,
I have been working on fixing my vacuum leak for some time now.  I have replaced every bit of rubber imaginable and sealed gaps where needed, but im still getting a "bad" reading on idle.
I recently noticed a plastic cap on the throttle bodies is melted.  All i can make out on it is "6/15"
Does anyone know what this is and if it would cause a leak?
  • Alexandria, VA
  • 1985 K100RT
Re: 1985 K100 Vacuum Leak
« Reply #1 on: August 17, 2015, 02:19:10 PM »
I don't have any caps on the front side of my TB's.
Offline bmw-rider
« Reply #2 on: August 18, 2015, 07:46:11 AM »
just the end cap on the throttlebody
« Reply #3 on: August 18, 2015, 06:18:12 PM »
+1 it's a dust cover only.  The other end of the TB has O-rings on the end of the pivot shaft that connects with the TPS.  Check for leakage in that area if you haven't already.
Offline smith913
« Reply #4 on: August 19, 2015, 02:35:59 PM »
Thanks for the input guys,  Ill look into replacing the dust cover at least.  the only other place with a small leak is where the manifold meets the block.
any other ideas that would show similar symptoms as a vacuum leak?
  • Alexandria, VA
  • 1985 K100RT
Offline F14CRAZY
« Reply #5 on: August 19, 2015, 04:55:22 PM »
How are you checking for vacuum leaks? I spray starting fluid onto areas it might occur while idling (I'm sure others will say not to do that, and with good reason, but)
  • Grand Rapids, MI
  • '87 K75C
Offline smith913
« Reply #6 on: August 20, 2015, 08:36:29 AM »
ha yup, thats how im checking for them as well
  • Alexandria, VA
  • 1985 K100RT
