Author Topic: Honda 60 moly paste problem  (Read 9273 times)
redtank
« on: August 14, 2015, 05:39:02 PM »
Hello,
So I wanted to lube my K75's drive shaft spines, so I get on Amazon and order Honda 60 moly past, being a Prime member I get it in 2 days, free shipping. So after receiving box I open only to find a small tube of M-77 assembly lube, so looking that up on line I find it's used on brake caliper shims when doing a brake job. I return M-77 and reorder.....next box, same thing, repeat one more time....same thing. Amazon is tired of sending me what I didn't order so all is returned. Now I look up Honda paste on eBay and vendors advertising it are selling M-77 paste as an updated item replacing 60 moly..... Anyone else running into this? I ended up lubing splines with Marine Moly past (comes in can with blue label).
Last question: what is best lube for clutch splines? My bike shifts easily, but is clunky (1st to 2nd is worst, down shifting lower gears noisy).
Thanks,
Cris
Re: Honda 60 moly paste problem
« Reply #1 on: August 14, 2015, 05:57:28 PM »
Honda has stopped producing Moly 60 so Amazon is fulfilling orders with a lubricant that is nearly equivalent (it's stated on the Amazon page for M77 as being a replacement for Honda Moly 60).  Another lubricant that is recommended for splines is Guard Dog 525 available from Beemer Boneyard.  I've read about one K-bike owner who has used assembly paste to lubricate splines but I'm not sure what the long term outcome would be.  You're looking for high moly content lubricant, >60%.
« Reply #2 on: August 14, 2015, 07:47:43 PM »
You might check with some local Honda dealers and see if any have any stock left of the moly 60.
« Reply #3 on: August 14, 2015, 08:32:40 PM »
I'm still using the same tube of Castrol Optimol Paste TA that the BMW dealer recommended in 2011.
Offline jay1622
« Reply #4 on: August 16, 2015, 09:15:59 PM »
For those of you looking for the Castrol product, a British website has it for an excellent price shipped for under $25.
https://www.motobins.co.uk
Search for part number 95815  and determine if that is what you're looking for.
  • Charlotte
« Reply #5 on: August 17, 2015, 10:25:08 PM »
+1 Guard Dog -- I have both it and the Honda Moly 60 and end up using the Honda Moly for everything but the gear splines -- GD is considerably tackier and seems like it would stick better.
Offline herseyb
« Reply #6 on: August 17, 2015, 11:34:01 PM »
Dang, is the M77 no bueno?  I took the word of the part guy at the honda dealer that it was an improved replacement when I lubed my rear splines after getting my bike.
  • Brooklyn
  • '93 K1100RS
« Reply #7 on: August 18, 2015, 12:00:12 AM »
The MSDS for Molykote-M77 states:
Molybdenum Sulfide: 50% - 70%
Dimethyl, Phenylmethyl siloxane, trimethyl-terminated: 20% - 30%
12-Hydroxy lithium Stearate: 1% - 5%
Looks like the moly content is >60% so it should be good to go.
Offline herseyb
« Reply #8 on: August 18, 2015, 10:25:23 AM »
sweet, I still have most of the tube.  Downshifting is getting a little stiffer than when I first had the bike, so I'm thinking it might be time to do the rest of the splines soon.  I can inspect the rear when I do, although I was hoping to hold out till winter.  I've only brought it from 15K to 18K, but it had sat outside for a while unused...
  • Brooklyn
  • '93 K1100RS
Offline Red
« Reply #9 on: August 19, 2015, 08:45:55 AM »
+1 Guard Dog - utilizing Guard Dog on both of my K bikes. I had switched from a combination 50% Honda 60 Moly and 50% Wurther mix.  :popcorm
Bill
1997 K1100LT
1985 K100RS.
'94 YZ250 Yamaha - sold
Markkeller
« Reply #10 on: August 21, 2015, 08:03:09 PM »
+1 on Guard Dog. I lubed output shaft on 1992 K75 at 19k miles. (1st time) using factory recommended Starburags NB30. 6k miles later in I go again due to difficult down shifts and caution. Starburags was nearly undectable. I think it had passed its shelf life when sold to me.
Guard Dog was sticky and slippery. After buttoning up, I second guessed applied amount. May have been slightly generous. Lubed the shaft and the clutch carrier. So far so good. Clutch not slipping and down shifts anytime I choose😊.
I love my K75.
