Author Topic: Oil Filter Cover Seal  (Read 3926 times)
redtank
« on: August 08, 2015, 01:42:41 PM »
I tried searching for information regarding the seal needed when changing engine oil filters on a K75, but didn't have any luck. My K75 is leaking oil from the round cover that has to be removed when changing the filter. Can someone point me in direction for the seal information, as I'm going to have to replace mine.
Thank you,
Cris
Offline RobP
Re: Oil Filter Cover Seal
« Reply #1 on: August 08, 2015, 02:07:29 PM »
There is an 88 x 3 o-ring that is often supplied with an oil filter kit.
11 13 1 460 425     - but double-check the part number for your specific year
  • Driftwood, TX
  • 1985 K100RS
« Reply #2 on: August 08, 2015, 03:32:08 PM »
Beemerboneyard has a kit with the O-ring and some crush washers for $5   http://www.beemerboneyard.com/7119963300.html
« Reply #3 on: August 08, 2015, 04:35:20 PM »
those bonerbeemyard ones are the ones i use... no problems noted at this point... although im thinking all it really needs is more no corn ethyl and more oil and less filters...
redtank
« Reply #4 on: August 08, 2015, 11:27:47 PM »
Thank you all for replying.....will get the kit
