Author Topic: ***FINISHED***: Father & Son 1988 K75S Rebuild  (Read 140235 times)
Offline jay1622
« on: August 03, 2015, 02:22:00 PM »
Good afternoon everyone. I am hoping to pick your brains and get some thoughts and/or advice as to what you think I am seeing and what some of the causes/remedies may be.
I managed to get a little bit deeper into the bike yesterday and stumbled onto a few things that I will want to address. When I took off the lower faring, both the front and the rear of the engine had significant dirt residue. There is no smell to it so I could not figure out if it is gear oil, coolant, or oil. I'm ruling out fork oil for now due to the fact that the seals appear to be in great condition, the fork tubes look great, and there wasn't any residue on the front of the fairings.  My initial guess is I have a coolant leak upfront and a gear oil leak in the back. I hope that's not the case, but considering where the paint has come off and how, that's what I'm thinking so far. Thoughts?  Recommendations? Clutch nut perhaps?
Worst case scenario, I will just replace the seal of whatever leaks I may find as I go; just hoping it's nothing significant when I get there.
Around the electrical wiring harnesses, it looks more like friction tape, as opposed to electrical tape. Does anybody know if this is true?
For the splines, I have and have been using the Honda Moly 60 for the splines on my RT. I will assume I can clean off the old crud and use the Molly 60 in its place? I've seen in places that I can, but I wanted to hear it from you guys whether or not there is a better option out there.
  • Charlotte
Offline jay1622
Re: Father & Son 1988 K75S Rebuild
« Reply #1 on: August 03, 2015, 07:30:29 PM »
Also...
Is there any way to tell if I have the 12mm or the 13mm rear brake master cylinder? Yes, I know measure... But where? Are they universal?
  • Charlotte
« Reply #2 on: August 03, 2015, 09:20:56 PM »
Also...
13mm for non-abs up to oct,1988, 12 mm for abs bikes and non abs 10/88 and later
Offline K75RT Keith
« Reply #3 on: August 04, 2015, 11:07:40 AM »
"Around the electrical wiring harnesses, it looks more like friction tape, as opposed to electrical tape. Does anybody know if this is true?"  Yes they used what appears to be friction tape.
"For the splines, I have and have been using the Honda Moly 60 for the splines on my RT. I will assume I can clean off the old crud and use the Molly 60 in its place? I've seen in places that I can, but I wanted to hear it from you guys whether or not there is a better option out there."    Honda Moly60 is fine.
* * * * Be aware that Honda is discontinuing Moly 60 * * * . So get it while you can find it.
Guard Dog makes a high moly lube and a paste.  The paste can be mixed in to a lower moly based lube if needed.
1990 K75RT
Offline jay1622
« Reply #4 on: August 22, 2015, 06:26:16 PM »
Hey all, I was conducting an inventory of what I have so far, and I figured it was worth sharing the pic. Am I missing anything?
Oh, and huge props to the parts department at Motorcycles of Charlotte. They worked with me more than I could have imagined and were very patient at helping me sort all of the stuff; and this still is not all of it.
  • Charlotte
Offline K75RT Keith
« Reply #5 on: August 22, 2015, 07:37:47 PM »
Looks like you emptied the trust fund.   Only way you'll know if you got all the parts you need is to commence wrenching.
1990 K75RT
« Reply #6 on: August 22, 2015, 08:09:05 PM »
don't forget to lube the barrel that holds the clutch cable to the hand lever.  I haven't bought that many BMW labeled plastic bags in the 28 years I've owned mine!
Offline jay1622
« Reply #7 on: August 22, 2015, 08:25:14 PM »
Thanks guys! Without sounding too much like a pitch man for the local dealership, the guys in parts really did me one solid. I hear what you're saying about the clutch cable. I have seen that time and time again in my old Yamaha Enduro bikes from the 80s. As for having all of the parts I will need? Time will tell, but I am pretty sure that this should be it with the exception of a few things. Namely, the final drive service plate I will have to fabricate to replace the seal and the clutch isolater I'll be making.
  • Charlotte
Offline RobP
« Reply #8 on: August 24, 2015, 08:21:18 AM »
Quote
What I do appreciate is that BMW will still supply parts for these bikes that are ~30 years old, at somewhat reasonable prices.   Can't say that for other brands.
  • Driftwood, TX
  • 1985 K100RS
Offline jay1622
« Reply #9 on: December 30, 2015, 10:10:14 PM »
Some updated Pics... Coming along quite nicely, or, so I hope!
  • Charlotte
Offline F14CRAZY
« Reply #10 on: December 31, 2015, 06:17:34 AM »
Quote
I wouldn't quite call BMW parts cheap but I haven't felt like I've been completely ripped off by them (yet). Nice they have things like clutch cables and discs in stock
  • Grand Rapids, MI
  • '87 K75C
« Reply #11 on: December 31, 2015, 10:23:40 AM »
Thanks for the photos.  If your engine work is even half as good as the photos, that bike will be a real beauty.
Offline 67charger
« Reply #12 on: January 02, 2016, 06:30:44 AM »
After seeing pictures of that head, It seems HEMI badges would be appropriate.
  • pennsylvania
  • 1993 k75
« Reply #13 on: January 02, 2016, 02:01:49 PM »
I've always wanted to own a Hemi I didn't realise that I've owned one for the last 17 years. :clap:
WooHoo Martin.
Offline Scud
« Reply #14 on: January 02, 2016, 07:01:47 PM »
Holy smokes - this is more like a restoration than a rebuild. FANTASTIC.
  • Carlsbad, CA
Offline jay1622
« Reply #15 on: February 21, 2016, 11:22:51 AM »
New clutch pack went in last night. He continues to help and show interest.
  • Charlotte
Offline jay1622
« Reply #16 on: February 23, 2016, 04:15:11 PM »
Mostly organized the garage (and my mind) today more than anything else, but I did manage to get a few things sorted. Got the rear suspension figured out, and the oil/water pump rebuilt and installed, and the air filter boxes sorted and ready for install as soon as I get some replacement fuel hose.
  • Charlotte
Offline sj2000
« Reply #17 on: March 11, 2016, 02:44:49 PM »
WOW, two thumbs up! :2thumbup:
  • Parker, USA
Offline Quiltzig
  • K Guy
« Reply #18 on: July 12, 2016, 05:38:58 AM »
Any progress to report since February?
I was enjoying following your restoration project.
  • Hamilton - New Zealand
  • K75S
1987 K75S - cafe racer project
2016 R9T (wifes ride)
2004 K1200RS
Offline jay1622
« Reply #19 on: July 12, 2016, 09:02:56 AM »
Tons of progress... Thanks for asking. ALL mechanical issues have been addressed and everything is back together. Fairings have been test-fit. Here's some progress related pics... Look to have her finished within the next few weeks.
  • Charlotte
Offline jay1622
« Reply #20 on: July 12, 2016, 09:05:14 AM »
As of last week...
  • Charlotte
« Reply #21 on: July 12, 2016, 11:17:08 AM »
 :2thumbup:Looking good I could never get any of my kids interested in anything mechanical.
Offline Quiltzig
  • K Guy
« Reply #22 on: July 13, 2016, 06:11:47 AM »
Thanks for the update. I only have daughters, and a grandson who is a whizz with computers but brings his motorbike to me to fix all the time. Glad to see the father / son bonding Taking place !
  • K75S
2004 K1200RS
Offline The Dude
« Reply #23 on: July 17, 2016, 12:45:58 AM »
You've created an hair loom...
Nice.
  • Auckland, New Zealand
  • K75s
Current.
TR6R 1973 from new.
All the best!
Offline jay1622
« Reply #24 on: August 04, 2016, 10:46:12 AM »
Started the final phase of the rebuild. The panels were cleaned with hot soapy water. Next will be stripping, scuffing and repairing what's broken.
  • Charlotte
