Author Topic: "While yer at it.." questions..... K1100RS apart  (Read 3366 times)
Offline KCinSB
« on: August 03, 2015, 12:45:00 PM »
Not that I want to spend any more money,....but I sure don't want to get this opened up again. With the clutch out, is there other stuff I should check while parts are on the bench? Of course splines were also the motivation.  I was thinking about alternator brushes. Can they just be changed out simple owner job?
 Bike has about 85K on it as best I can tell.  (speedo was broke for awhile)
  • Santa Barbara, CA
  • SOLD
Offline orforester
Re: "While yer at it.." questions..... K1100RS apart
« Reply #1 on: August 03, 2015, 12:50:26 PM »
If you have the clutch out, I would replace the rear engine seal, if it is not now leaking it will soon, and as long as you are in there.  I am sure there is a "how to" on this site.  I had the seals on my Tranny replaced, but then I am anal, it cost about $265, but my guy is really cheap, but you might think about it.  Starter brushes for sure.  Not sure about Alternator brushes, I have never replaced them.  Of course lube everything when it goes back together.
Fun times!!
Bob
1989 K 100 RS se (SOLD)
1985 K 100 RS, now RT
2008 R 1200RT
