Author Topic: I took my gas cap off to...  (Read 4528 times)
Offline beemuker
« on: August 03, 2015, 12:38:14 PM »
I took my gas cap off to have a look see, and the gasket has a cork/powder-like substance on both sides. was that some kind of cork or sealant that has deteriorated. ? the rubber gasket looks fine and the metal tank surface does not look corroded, just this residue on it. I guess I should order a new gasket and maybe some other small parts [tranny crush washer, fork cover cap] best online source? I would think the new gasket would require no sealant. tips?
  • Panama City, FL
Offline Tuco
  • Gone ridin' !
  • Ready, Set, Go!
Re: I took my gas cap off to...
« Reply #1 on: August 03, 2015, 07:02:11 PM »
I dont recognize whatever that stuff is/was. However in your third photo, it appears that you still have the unleaded fuel nozzle restrictor still attached. Remove it and you find the tank easier to fill and a bit more capacity.
  • Waldport, Oregon
Offline beemuker
« Reply #2 on: August 03, 2015, 07:06:39 PM »
thanks, i was wondering if I could get rid of it.
  • Panama City, FL
Offline thegingerbeardman
« Reply #3 on: August 03, 2015, 08:19:04 PM »
I have had 2 K bikes with the same residue.  Both sat for at least a few years.
as the parts fiches don't show anything else that should be there i.must conclude it is some kind of corrosion or residue leftover from gas that has sat for Way Tooooo LONG
clean it off, I replaced the rubber thing too as mine were fairly hard, and keep on riding
Offline vintagemilano
« Reply #4 on: August 04, 2015, 04:14:10 PM »
It's corrosion, when aluminum corrodes the resulting powder is a different color than when ferrous metals corrode.
  • Cranbrook, BC, Canada
  • 1990 K75RT
Non bricks include
06 Yamaha FZ6
1996 Yamaha xt225
1993 Suzuki GSF400
Offline beemuker
« Reply #5 on: August 04, 2015, 04:51:31 PM »
I guess I need to clean it off without getting it into the tank. might be easier with the tank off. I could wait until I need to do an air cleaner and coolant flush this winter. It's probably been that way for awhile. do I need to do this asap. ? should I put some kind of oxidation inhibitor to prevent this in the future?
  • Panama City, FL
Offline herseyb
« Reply #6 on: August 04, 2015, 05:27:11 PM »
I had the same stuff on my bike that sat for god knows...
I did clean it when I had the tank off, plugged the whole beneath to make sure none of it got in the tank.  Wound up replacing the rubber gasket too.   The tank didn't stop going ffffffffsssssssssssssssssss  under pressure until I also replaced the rubber.
  • Brooklyn
  • '93 K1100RS
