Author Topic: So more is not better ?? Opps........  (Read 3846 times)
Offline KCinSB
« on: August 01, 2015, 01:11:03 PM »
Reading another post, I see a comment about oil level, and I think I may also be guilty.  I have often filled my K1100RS above the center dot in the sight glass, and didn't think much about it. I guess BMW engineers would put that Dot exactly where they want it though.  Maybe that is why I have noticed a drip out the bell housing, or is a contributing factor.
  • Santa Barbara, CA
  • SOLD
Re: So more is not better ?? Opps........
« Reply #1 on: August 01, 2015, 03:56:36 PM »
The center dot is ideal, but the real 'high' limit is the level of the red circle around the edge of the sight glass. It defines both the low and high. As long as you aren't above that you should be fine.
Offline KCinSB
« Reply #2 on: August 01, 2015, 08:26:36 PM »
OH, well I guess I'm still OK then, since I do keep a bubble above the oil.  Just curious, Thanks.
  • Santa Barbara, CA
  • SOLD
Offline K75RT Keith
« Reply #3 on: August 03, 2015, 12:02:25 PM »
Drips out of the bell housing means either the rear seal is failing or the o-ring is hardened up.  If you're lucky it won't contaminate or soak the clutch plate.
1990 K75RT
Offline KCinSB
« Reply #4 on: August 03, 2015, 12:12:50 PM »
To late for that,...... Clutch was slipping, but the main seal looks OK.
  • Santa Barbara, CA
  • SOLD
