Author Topic: K75 pulls to the right.  (Read 5502 times)
Offline beemuker
« on: July 29, 2015, 05:26:08 PM »
I don't notice it too much with my hands on the bars, but if I take my hands off [ purely for test purposes] the bike pulls right. I have to get my weight way off center to keep er straight. any way to fix this, is it broken?
  • Panama City, FL
Offline thegingerbeardman
Re: K75 pulls to the right.
« Reply #1 on: July 29, 2015, 06:20:58 PM »
Tire pressure, worn tires, and steering bearings would be my first checks.
I assume you haven't hit anything recently, and this is a new phenomenon.
Offline beemuker
« Reply #2 on: July 29, 2015, 08:57:53 PM »
new Pirelli sport, tire pressure good, bearings?. I think it was like this when I got it 1k ago. just never bothered me.
  • Panama City, FL
Offline motodude
« Reply #3 on: July 29, 2015, 10:06:23 PM »
I think they all do that.  I think it's because the wheels are slightly off-set.
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
Offline beemuker
« Reply #4 on: July 29, 2015, 10:16:15 PM »
Tom
I was thinking this.
  • Panama City, FL
Offline F14CRAZY
« Reply #5 on: July 29, 2015, 10:42:38 PM »
I think you can play with rear wheel spacers to try to fix it
  • Grand Rapids, MI
  • '87 K75C
« Reply #6 on: July 29, 2015, 11:26:02 PM »
I am a novice motobricker, so my guesses come from general motorcycle experience coupled with ignorance.  Head bearings can develop little dents in the races that give a "set" position.  This is way more common with ball bearings.  I am not into this addiction far enough to k ow what kind of bearings should be or are installed on your bike.  If they're rollers it's probably not the issue.
it sure sounds like The Nature of the Beast from other responses, though it's worth eliminating as many other ppossibilities as you can
Offline Freelancer
« Reply #7 on: July 29, 2015, 11:58:39 PM »
One question:
When you guys let off of the throttle, do you have some form of
Cruise control or throttle/friction lock to keep the rev's stable?
If not then, imo, the issue is less likely the wheel offset and more the rotational force of the engine.
I say this because as long as my RPM's are stable she runs pretty straight. If the throttle is accelerating she goes one way and goes the other on deceleration.
Later,
Freelancer
1991 K100RS
« Reply #8 on: July 30, 2015, 12:14:43 AM »
Wheels are offset from the factory.  Maximum permitted wheel offset: 5 mm.  Wheel rim of equal width will have an  offset of 4mm.  Wheels with different front and rear widths will have a typical offset of 1.5mm.  Playing with spacers is best done in conjunction with an offset gauge.  See page 46-79.0 of the oem manual.
