Author Topic: How many crush washers on master cylinder banjo bolt?  (Read 3525 times)
Offline Andrewck
« on: July 01, 2015, 10:19:53 AM »
My front brakes are mushy and I will bleed them later today.  When looking at the front master cylinder, I noticed there is only one copper crush washer on the banjo bolt.  Clymers manual doesn't give a clear look at the banjo bolt or a diagram on replacing the upper brake line.  I did replace my front brake lines with Spiegler, but cannot remember if they sent additional crush washers.
Would somebody please take a photo of their front upper brake line with banjo bolts and crush washers.  Need to know if one is correct or if I need to go purchase another.  Would you also happen to know the size of those crush washers if I do need to purchase them?
1990 K75S
Offline dougrs
Re: How many crush washers on master cylinder banjo bolt?
« Reply #1 on: July 01, 2015, 10:57:10 AM »
you need two, one on either side of the brake line fitting.
  • MD
  • '89 Yamaha FJ1200, '94 BMW K75
