Author Topic: Can't get transmission back on  (Read 6084 times)
« on: June 30, 2015, 11:10:43 PM »
Should have been a pretty straightforward clutch spline lube on Ludwig's 95 K75 with 34K miles and fine looking splines. Problem arose when we tried to get the transmission back on. It looks like the clutch disk splines just will not mate with the transmission shaft splines. We're using one of Ken Lively's clutch centering tools and 78mm guide bolts. Here's what we've done:
Used clutch centering tool, torqued down clutch pack -- jiggled, wiggled and tapped with a wood block -- won't go.
Loosened the clutch pack so the clutch disk would be able to self-center when it mated with the transmission input splines -- won't go.
To make sure there's nothing else going on in there, removed the clutch pack and slipped the transmission on -- went in like butter. So we know it's being blocked by the clutch pack.
Put the driveshaft on the output shaft to turn the input shaft while pushing in the hopes that the splines would mate -- no cigar, they will not mate. The input shaft turns, seems like it is trying to grab something, but will not lock in.
Tested the clutch disk splines on the the input shaft splines to see if they like each other -- no problem there, they mated right up.
This is probably an alignment issue but I've never had this much trouble getting a transmission back on and I've done it seven or so times. Could this be due to a misalignment of the spring? Too frustrated to continue -- anyone have any tips or suggestions?
Thanks, Motorhobo, helping fellow Motobricker Ludwig...
Pretty stumped here --
Re: Can't get transmission back on
« Reply #1 on: July 01, 2015, 12:02:07 AM »
I would double-check the clutch spring is not in backwards.
I've had my clutch off and gearbox removed a bunch of times. Whenever the splines were not mating it would help to turn the gearbox output shaft (gearbox not in Neutral) until the gears meshed. Make sure the rear of the gearbox is not sagging. Even using the alignment screws the gearbox must be supported to be 100% horizontal.
Offline F14CRAZY
« Reply #2 on: July 01, 2015, 06:19:02 AM »
I press the clutch release lever while putting it on
  • Grand Rapids, MI
  • '87 K75C
Offline ludwig
« Reply #3 on: July 01, 2015, 08:43:10 AM »
Have been trying all above and still no go.
  • manhattan
  • 94 k75s 95 k75s 81 Yamaha XS850s (gone but never forgotten)
ludwig
« Reply #4 on: July 01, 2015, 09:06:25 AM »
I've wrestled with a K75 transmission more than once , just like this. It's because the clutch splines are not lining up.  Putting the transmission in 5th gear helped alot.  After each attempt, I would slightly rotate the clutch input  shaft a couple degrees and try again; eventually it worked.
Offline Elipten
« Reply #5 on: July 01, 2015, 05:54:28 PM »
Rubber mallet, some gentle taps works for me.
  • San Antonio, TX
  • 1990 K75RT
Offline ludwig
« Reply #6 on: July 01, 2015, 10:11:01 PM »
Unfortunately it took a lot more than a hammer!
This one was not fun. But it's back together.
I think motor hobo is writing up  a play by play for future reference and if he does not I will.
Thanks for the mojo.
  • manhattan
ludwig
Offline pallum
« Reply #7 on: July 03, 2015, 02:16:32 AM »
It's hard to tell when you've got the transmission in your hands and you're down on the ground wrestling with it, but if it's hanging up on the frame, it may be tweaked. My symptoms were spline lubes lasting less than 10k miles before the downshifting problems returned. Probably not an issue for you, but it's something to keep in mind as it took me years to figure out.
  • Federal Way, WA
« Reply #8 on: July 06, 2015, 01:20:31 PM »
Wouldn't want anyone else to have to suffer through this so here's the log:
There appeared to be two issues here.
1) Spring not properly aligned.
2) Gear splines not aligned.
Due to one or both of these, the transmission would slide forward to about 1.25 inches from mating, then would stop and no amount of wiggling, shaking or tapping would budge it.
Issue 1) Spring slipped out of position during clutch pack alignment. Result: clutch pushrod is obstructed from bottoming out where it rests on the spring, which prevents the transmission from sliding forward into place. To prevent this:
1 -- Before removing clutch pack: -- insert the clutch pushrod as far forward as it will go, pinch it between your thumb and forefinger, pull it out, and measure the distance from your thumb to the tip of the rod. Doesn't have to be exact but it should be in the 2.125 - 2.25" range. This is the 'before' measurement.
2 - Install the clutch pack and make sure the distance the clutch pushrod slides forward matches the 'before' measurement above. If it doesn't, something's not right -- shine a light in the bore and confirm that the spring isn't centered. At this point you'll have to install the clutch pack as many times as it takes to get it aligned right. Note that every time you do it the tooth washers will lose integrity -- can't hurt to have a couple sets of these on hand.
Issue 2 - Splines not aligning
I've installed K75 transmissions six times and have never experienced this to the extreme that the teeth simply won't mesh, but obviously that can happen because it did. If you know the pushrod is bottoming out at the spring, but the transmission still hangs up about 1.25" out, you'll have to get the teeth to align. Guide pins are a huge help, and jacking up the transmission so the bottom of the case lines up with the bottom of the bell housing makes things easier. If it still stops at about 1.25" out:
1 - Make sure the transmission clears the frame on both sides
2 - Put it in gear, turn the output shaft a small distance as Tim and rbm suggested below, and give it another shove forward until the teeth mesh and the unit slides forward. This may take multiple attempts to get it aligned right. To do this, I just attached the driveshaft to the output shaft and turned the driveshaft. First two times it didn't go, but the third time is slid right in.
Tapping with a block and hammer can help nudge splines that are barely misaligned - that's always worked for me in the past. But if they are completely misaligned as these were then no amount of whacking will force them. I can confirm that when all is aligned properly the unit will slide in with basically no effort at all and all that's left to do is tighten the bolts.
Once that is done, there's the issue of aligning the transmission with the frame so you can screw in the mounting bolts. That can be a challenge since due to the funky angles all around there's nowhere to set a bar to use as a lever. I think once I even tried to lever against the coil mounting bracket. I discovered at that point that 1) the part is plastic and 2) you can get them pretty cheap on evilBay since I destroyed the original by levering off it. Since then, I do this:
1) Put the bolt in whichever bore allows you to use the lever action shown in 2) below on the other side of the frame. What I mean by that is that it's easier to use leverage at this point to shift the frame upwards than it is to shift it downwards. If the frame is too high on one side, maybe it's best to remove both bolts, then put a screwdriver in the bore on the side that is higher and try to shift it downwards, so that the other side is lower. You should be able to line up one side pretty easily by just sticking a Phillips screwdriver in there as long as there's no bolt in the other side.
2) Cover a heavy duty screwdriver or pry bar with a cloth at the point shown in the picture and use leverage to push the frame upwards in relation to the bore in the transmission.
From this lever position you should be able to get enough adjustment to get the mounting bolts in.
Hope this helps -- if you have other tips or corrections feel free to share them.
