Author Topic: fork wobble  (Read 4146 times)
Offline MonkeyMcBean
fork wobble
« on: June 28, 2015, 12:42:46 PM »
My front fork used to always track smooth and straight. Suddenly, it has started to wobble under braking and deceleration. I have no idea what is happening. Does anybody have any ideas? Thank you!
  • North Dakota, USA
  • 1993 k75s
This is it. F*** it. It is what it is.
Re: fork wobble
« Reply #1 on: June 28, 2015, 01:32:54 PM »
greetings monkeymcbean...
generally wabbles are from tiors... front or rear... or bent wheels...
butts wabble under front braking is generally warped rotor or whack bobbins...
butts i donts thinks you gotts bobbins on that seven fitty... so i would be looking for warped rotors 1st...
Re: fork wobble
« Reply #2 on: June 28, 2015, 01:35:26 PM »
The wobble isn't due to braking, because it happens under non-braking too. Maybe I should gethe my wheels re balanced.
  • North Dakota, USA
  • 1993 k75s
Re: fork wobble
« Reply #3 on: June 28, 2015, 01:40:27 PM »
awech1tt... i musta miss interpreted "wabble under braking" as meaning when you braked you gotts a wabble...
so... if its not wabbling under breaking its proally not warped rotors...
only on deceleration... if feeling it in the forks it could be final drive pillion bearing going whack...
Re: fork wobble
« Reply #4 on: June 28, 2015, 02:04:57 PM »
could be excessive freeplay in the headstock.  Have you checked?
Re: fork wobble
« Reply #5 on: June 28, 2015, 04:51:05 PM »
Yeah, my bad. I should have been more clear.
  • North Dakota, USA
  • 1993 k75s
