Author Topic: 96 K1100RS  (Read 5750 times)
Offline motomann
96 K1100RS
« on: June 21, 2015, 05:34:47 PM »
Hi, I just purchased a 96 K1100RS with ABS. When I turn the ignition on only the right abs light flashes...nothing on the left one. Checked the bulb and it's ok. Did a reset and right light still flashes.
Reset plug on ABS unit. Same solitary light flashing. Any suggestions??
  • Perth, Ontario, Canada
  • 96 K1100RS, 99 R1100S, 02 R1150R
Offline Inge K.
Re: 96 K1100RS
« Reply #1 on: June 21, 2015, 06:26:23 PM »
Welcome!
You should hear a relay clicking in the relay box....in the same sequence as the functioning lamp.
If not check that the relay is present and funtioning correctly.
In the relay box you have 6 small relays of the same size, the rear left is for the warning lamp
and is the only relay that is blue.....this is a NC relay.
  • Norway
Offline motomann
Re: 96 K1100RS
« Reply #2 on: June 21, 2015, 07:09:16 PM »
Thanks, I'll check it out
Offline John Cannon
Re: 96 K1100RS
« Reply #3 on: July 31, 2015, 11:31:13 AM »
I just bought a 1997 K1100LT with the right-hand only ABS light flashing. Did you ever resolve your problem?
  • Salem, VA
  • 1997 K1100LT
Offline motomann
Re: 96 K1100RS
« Reply #4 on: July 31, 2015, 06:01:24 PM »
Hi John
I recently purchased a 96 k1100RS. Both ABS lights were not flashing. I checked the fuse box and the blue abs relay was missing and the bulb on the right was burnt out. On the relay block there was a plastic plug where one of the relay prongs would plug into. I removed the plug, replaced the bulb and installed the relay.....the relay clicks and ABS light on the right flashes but nothing on the left side. So I still have the problem .
Rob
Offline John Cannon
Re: 96 K1100RS
« Reply #5 on: July 31, 2015, 09:43:15 PM »
There is more drama to the ABS saga than I first imagined. I have seen more than one account where the lights have been disabled to sell to an gullible buyer. I now have found that my ABS warning relay was removed hence only the right light was flashing. Replacing temporally with a NO relay confirms that at least this part or the system is working. I have now ordered the correct NC relay so I can proceed with a less confusing diagnosis. What I need is a list of classic failure modes to check. I'm sure there is info out there; I was thinking before that my problem was unique relating to a single light flashing. I'll report later. Please do the same.
  • Salem, VA
  • 1997 K1100LT
Offline tsnap
  • recovering Polygacyclist, juvenile polycyclic disease
  • Retired Unprofessional Whacko Driver
Re: 96 K1100RS
« Reply #6 on: February 07, 2016, 03:51:09 PM »
motpomqn, qny good news?
tom
  • Kirksville, MO
  • K1k1100 Radar Sloth1994 48K ABSII no shame wall 4 me
just plain tom, he is a dirt mean man
Offline John Cannon
Re: 96 K1100RS
« Reply #7 on: February 07, 2016, 05:37:47 PM »
My bike has been stored for the winter and so I haven't had a chance to look at the ABS problem. I hope to do some more when the weather warms up and I'll make a new post to that effect.
  • Salem, VA
  • 1997 K1100LT
Online Laitch
Re: 96 K1100RS
« Reply #8 on: February 07, 2016, 07:13:21 PM »
What I need is a list of classic failure modes to check. I'm sure there is info out there . . .
Is this any help, John?
http://www.motobrick.com/index.php/topic,538.msg1312.html#msg1312
