Hi all,
Here are some pics of a very dirty intake area. They show where I relocated the Fuel Pressure Regulator.
I ended up only insulating the little curve between the fuel rail and the regulator. You'll see "5 V's" cut into nto the outer insulating hose on the inside radius so that it would bend without kinking. This also helps the fuel line to not kink.
The reason for the positioning are several:
1st) It allowed for the easiest mod of the oem bracket. This allowed me to use the same screw mounting holes in the bracket.
2nd)This allowed the use of the screws directly outside of the original location(Only place it really fit without custom brackets, having to clearance the fairing or "miles of extra fuel line.)
3rd) Most importantly, this fuel line routing has the smallest amount of line that sits in the "hot box" area.
(My theory was that the FPR's position and all the extra hose that sits in the hot area was the cause of the "fuel heating" hot tank problem.)
4th and finally) This was the cheapest way to test out the idea. :2thumbup: At some point I could try to make it prettier but seeing as the fairing covers it, I'm thinking "if it works, don't "F" withit. :yes
Before this mod the tank would start the thigh burn at the half tank on a 90 degree day.
Now, I can run her to the fuel light on a 98 degree day with no warm feeling.
If you have questions about this, feel free to ask.
Here are the pic's,
Freelancer
