Front brake master cylinders
Topic: Front brake master cylinders (Read 4905 times)
kenray
Motobrick Curious
June 06, 2015, 10:36:58 AM »
What is the difference between a k75/100 non abs front brake cylinder vs an abs front brake master cylinder. Thanks for any info. Ken in Katry Tx.
Katy Tx. (West Houston area)
1989 K100rs (se)
1989 k100rs
TimTyler
Adrninistrator
Re: Front brake master cylinders
Reply #1 on:
June 06, 2015, 10:56:49 AM »
I think the piston in the ABS version is a little bigger.
Inge K.
Reply #2 on:
June 06, 2015, 10:59:16 AM »
The ABS master have a adjustement screw at the lever, and a harder material at the lever end of the piston.
Norway
TimTyler
Adrninistrator
Reply #3 on:
June 06, 2015, 11:16:15 AM »
Quote from: TimTyler on June 06, 2015, 10:56:49 AM
I think I'm wrong. I just checked the fiche and it appears all the rear pistons are 12mm and all the front pistons are 13mm.
Inge K.
Reply #4 on:
June 06, 2015, 07:43:28 PM »
Quote from: TimTyler on June 06, 2015, 11:16:15 AM
Rear master did change from 13mm to 12mm during -88.
Norway
