Author Topic: K75 decided to take a break on the side of the road  (Read 2829 times)
Offline scotlandkane
« on: May 25, 2015, 11:45:10 PM »
Hey folks...
So my 1995 K75 seemed to be running smoothly until it decided to quit on me and left me on the side of the road. At first I thought it had run out of gas, but there was plenty in the tank. When I tried to start it up it would turn over but not fire up.
Should I try to replace the fuel filter first?
Suggestions?
Thanks!
Grace
  • North Carolina
  • 1995 K75
Offline ssray
Re: K75 decided to take a break on the side of the road
« Reply #1 on: May 26, 2015, 12:36:23 AM »
Fuel filter and whilst your in there look for any bits of rubber, use a torch not a match to light up the area though, how many miles has your K?
« Reply #2 on: May 26, 2015, 06:48:34 AM »
ssray it has 67,000 miles on it
  • North Carolina
  • 1995 K75
« Reply #3 on: May 26, 2015, 07:23:44 AM »
Do you hear the fuel pump running when you press the starter switch?
Check the 4pin connector at the right rear of the fuel tank. Not uncommon for bad/dirty electrical connection here and cause fuel pump to stop.
