Author Topic: Stripped Thread Repair for Gas Cap Screws  (Read 4389 times)
Offline RobP
« on: May 20, 2015, 09:48:53 AM »
A couple of the  gas cap retaining screw holes are stripped out on my tank. I have found thread repair kits for M4 course threads, but not the fine threads.  Has anyone had any luck drilling and re-tapping for M5 screws?  This approach would probably involve re-countersinking the holes in the cap assembly.
Or another solution?
  • Driftwood, TX
  • 1985 K100RS
Re: Stripped Thread Repair for Gas Cap Screws
« Reply #1 on: May 20, 2015, 08:21:43 PM »
Check with a local machine shop?
If they have/can tap M4 fine, the lip area of the tank is aluminum, possibly they could "fill" the stripped hole with aluminum filler and then re-tap the hole again.
« Reply #2 on: May 20, 2015, 09:29:51 PM »
Or drill the hole all the way through and use a longer screw and a bolt?
Is that a bad idea?  :dunno
Offline RobP
« Reply #3 on: May 20, 2015, 10:03:03 PM »
I pulled out my tap set to re-confirm the thread size, and found that the threads appear to be M4 x .70, and was able to find thread repair inserts in that size.
I originally got bolluxed up when I read the parts fiche and the screws were listed as M4x10, but those appear to be the WxL dimensions, not the thread size.
  • Driftwood, TX
  • 1985 K100RS
Offline wmax351
« Reply #4 on: May 21, 2015, 01:14:50 PM »
JB Weld may be your friend here.
I'd drill and tap larger to give the JB weld something to grip. Then fill with JB Weld, drill and tap. I wouldn't torque it fully, but it should hold pretty well.
  • Albuquerque, NM
Bikes:
