Author Topic: An interesting symptom...  (Read 4163 times)
Offline TaosBrick
  • RedHotMotoBricker
« on: May 06, 2015, 03:56:06 PM »
Ok, now that I have my steering head sorted, that brings me to the next conundrum, in the performance dept.
  Ol' Chile Red has developed a curious phenomenon, where when I am going at HiWay speed and cut the throttle and pull in the clutch, she quickly winds down and dies.  She'll start again with some cranking and a mostly open throttle after turning over for about five seconds or so.
  She is also slightly more sluggish at 59k miles than when I got her at 28k, and seems to take a bit more time warming up.
  I will note that I've yet to check the valve clearances since I got her in August of 2011, and I've no idea how well the air flow meter may or may not be functioning.
- Samurai Maxim
Offline subforry
Re: An interesting symptom...
« Reply #1 on: May 06, 2015, 05:54:40 PM »
I test rode a K100 that had the same problem.  My thoughts were that when the throttle is closed the EFI stops opening the injectors.  Once the engine RPM drops to idle or so it starts opening the injectors again - like when the clutch is pulled in.
But I think on the bike I rode and yours that the injectors are not opening again and the engine dies.  If it was a Mercedes with mechanical fuel injection I could tell why.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1990 Suzuki Katana 1100 (GSX1100F) - sold
1996 BMW K1100RS
2009 BMW K1300GT
« Reply #2 on: May 06, 2015, 07:41:57 PM »
... I've yet to check the valve clearances since I got her in August of 2011...
Yeah - That's what I would suggest.
« Reply #3 on: May 06, 2015, 08:04:11 PM »
Then I would suggest checking the TPS adjustment.
