Author Topic: Throttle cable adjustment?  (Read 9475 times)
Offline beemuker
« on: May 05, 2015, 10:50:34 AM »
I have some play in my throttle and I've searched and found no mention of how to adjust it, if possible. I see the adjuster for the "choke", but can't locate one for the throttle cable. maybe I should follow " if it works, don't fix it"?
  • Panama City, FL
Offline TX brick
Re: Throttle cable adjustment?
« Reply #1 on: May 05, 2015, 02:15:51 PM »
My 91 has a boot on the cable where it exits the throttle housing. Under that boot is an adjuster.
Ron
91 K75RT
Belton Tx
Offline beemuker
« Reply #2 on: May 05, 2015, 02:54:27 PM »
thanks, I'll look
  • Panama City, FL
Offline TaosBrick
  • RedHotMotoBricker
« Reply #3 on: May 06, 2015, 09:17:05 AM »
There is also another adjuster at the throttle body end of the cable.
- Samurai Maxim
Offline beemuker
« Reply #4 on: May 06, 2015, 10:52:50 AM »
is that easy to get to, i dont see it
  • Panama City, FL
« Reply #5 on: May 06, 2015, 11:23:33 AM »
Mine doesn't have a cable adjuster on the throttle body end, just a throttle body idle adjustment screw that I think we're not supposed to adjust.
The cable should be adjusted up at the handlebar end.
Offline beemuker
« Reply #6 on: May 06, 2015, 12:04:32 PM »
thanks, looks easy enough
  • Panama City, FL
Offline zenitramnaes
« Reply #7 on: August 14, 2018, 06:58:43 PM »
Where can I find an adjuster? The bike I just bought was using a Bilwell throttle and had removed the stock levers. I put them back on but I'm missing this adjustment option.
  • USA
  • '85 K100rs
« Reply #8 on: August 14, 2018, 07:35:45 PM »
greetings..
i may have one... whats the part number...
« Reply #9 on: August 14, 2018, 07:37:43 PM »
Not sure, having a hard time finding this one on realoem.
  • USA
  • '85 K100rs
« Reply #10 on: August 14, 2018, 07:43:23 PM »
it maybe part of the oe bowden cable...
« Reply #11 on: August 14, 2018, 07:47:48 PM »
All of the cables I'm seeing for sale on different sites don't have the adjuster. That and not seeing it on realoem led me to believe that it's a separate part or maybe the updated version of the cable but I'm not sure.
  • USA
  • '85 K100rs
