Author Topic: My K75 project. My first BMW ever  (Read 7926 times)
Offline k75_cafe
« on: May 05, 2015, 07:14:39 AM »
My name is Alex and I bought a K75 1990 last year. It's been sitting for 4 years with the previous owner and i started working on it in march. I/m looking to make it in a cafe racer. I'll put some photos in a few minutes. Today when i put the battery back on it I found that the bike wants to start on it's own without the key even.The electromotor keeps turning but i don't hear the fuel pump working . So although it's wants to start it doesn't. What to look for ? what might be the problem ?
  • london
  • k75 1990
Re: My K75 project. My first BMW ever
« Reply #1 on: May 05, 2015, 08:50:59 AM »
... when i put the battery back on it I found that the bike wants to start on it's own without the key even.The electromotor keeps turning...
Probably a stuck starter relay caused by a weak battery.
Offline k75_cafe
« Reply #2 on: May 05, 2015, 08:54:23 AM »
Fully charging the battery will solve the issue ? Or do I need to take further action ? take it down ... clean it ... replace it ... look for new one ?
  • london
  • k75 1990
« Reply #3 on: May 05, 2015, 09:03:03 AM »
If it's a stuck starter relay you can try tapping/whacking the relay with a tool and maybe it will un-stick. Once they stick, they are more prone to stick in the future, even with a good battery.
You can replace the relay (they're not cheap) and be careful to use a good battery with good electrical connections.
I have disassembled relays and sanded the previously stuck connections so they'll be less likely to stick. One is in my bike now.
Offline k75_cafe
« Reply #4 on: May 11, 2015, 08:56:56 AM »
Sorted out the relay now strugling with the running light staying on during bike being off and turnin off when bike is on.
Also I am lookin for a pair of new radial tyres . Open to sugestions
  • london
  • k75 1990
Offline telecaster-custom
« Reply #5 on: May 21, 2015, 10:18:53 PM »
Just starting my own K75 project.  Couple questions, if you don't mind.
What headlight assembly did you use?
What strap-ons/grips?
What plans do you have for instruments/gauges?
  • Cleveland, OH
  • 1991 K75S
