Author Topic: fuel leak  (Read 4039 times)
Offline zilla
fuel leak
« on: May 04, 2015, 05:14:11 PM »
On my 85 K100, I had a pretty good leak from looks like the sender from the gas gauge.
I apologize in advance, but the part that was loose was where the wiring connects.
I did get it tightened up, but was wondering if there was supposed to be a seal in there or not?
It looks like the sender is no longer available.
Any help or advice would be appreciated.
Re: fuel leak
« Reply #1 on: May 04, 2015, 05:38:59 PM »
GASKET RING,  part # 61 31 1 459 448.
Offline zilla
Re: fuel leak
« Reply #2 on: May 04, 2015, 08:35:48 PM »
Thanks a lot.
Does that seal sit inside that big nut?
Offline zilla
Re: fuel leak
« Reply #3 on: June 29, 2015, 05:06:14 PM »
I finally got that gasket. How in the world do I get the sender apart to put it on?
I've got the sender out of the tank.
And the manual I downloaded shows a different style than what I have.
DISREGARD
I was making things too complicated.
Hope that fixes the problem. Otherwise I think it's the sender itself. Which is no longer available.  :mbird
SHIT!
Doesn't look like it. Appears to be leaking around the sender itself.  :swear:
Any way to cap it off and not use the sender? Thing doesn't work worth a damn anyway. I always go by the trip meter.
