Author Topic: Are these kill switches a known problem?  (Read 6914 times)
Thorfinn
« on: May 02, 2015, 07:06:07 AM »
My K75 has been sitting in the garage over winter (yeah I know, but I live in Cornwall..!)  :euro and started and ran fine when I took it for its MOT test last week. Now, not so good. Totally dead. I know the battery is fully charged.
I'm suspecting the kill switch - wondered if it was a known issue on K-Bikes? It was in the "Off" position throughout the bike's hibernation.
Thanks for any ideas,
Thorfie
Re: Are these kill switches a known problem?
« Reply #1 on: May 02, 2015, 07:16:28 AM »
Have a look at last picture on page two.
...if your horn or headlight doesn't function, check the ignition switch instead.
Thorfinn
« Reply #2 on: May 02, 2015, 08:59:00 AM »
Thanks Inge. I was hoping it wasn't the Ignition switch - I rebuilt it just last year! Mind you, we must remember the old saying:
"If it ain't broke, I ain't worked on it yet" :oops:
So it could be me being as cack-handed as ever. Just one thing: Doesn't the killswitch disable things like lights and horn too?
« Reply #3 on: May 02, 2015, 09:32:19 AM »
No.......after the ignition switch the circuit split in two, one wire to the kill switch...
the other to the load shedding relay (lights, horn ++).
Offline motodude
« Reply #4 on: May 02, 2015, 05:53:16 PM »
You may want to disassemble the switchgear and clean the contacts.  Just be careful that you don't lose any screws.  After removing from the handlebar, put in a shoe box or similar to catch them.
Tom
'95 K75RT
'90 K75RT
'87 K100RS Motorsport
Thorfinn
Re: Are these kill switches a known problem? - SOLVED!!
« Reply #5 on: May 21, 2015, 12:05:43 PM »
Thanks to all for advice on this. The killswitch and the ignition switch were fine in the end...BUT the connector under the tank for the ignition switch was intermittent. I cut it out and got soldering - seems to have done the trick!  :riding:
Cheers
Thorfie
