Author Topic: Resealing oil pan and timing cover  (Read 10493 times)
Offline F14CRAZY
« on: April 29, 2015, 09:09:16 AM »
Well I fortunately got my oil/water pump to stop leaking. Yay.
I probably should done it while I was messing with the pump but it seems that the timing chain cover and oil pan are also seeping. I don't know if those are the technical brick terms but I think you guys understand the parts I'm talking about.
I'm thinking about removing them and applying new RTV when I do my next engine oil change. Is there anything special I need to keep in mind? Anything to replace while I'm in there?
I think I've heard about timing chain sliders becoming worn...are the sliders, chain, or sprockets a wear item that I should inspect?
Anything else?
  • Grand Rapids, MI
  • '87 K75C
Offline kris
Re: Resealing oil pan and timing cover
« Reply #1 on: April 29, 2015, 09:19:13 AM »
The only thing I can add at the moment is to check/ clean your oil sump filter when you have the pan off. Haven't done the rocker cover yet.
"I got bike fever bad!!"
Offline RobP
« Reply #2 on: April 29, 2015, 09:45:05 AM »
Quote
I felt your pain in your other thread.  So, what were the final steps taken to resolve the issue?
  • Driftwood, TX
  • 1985 K100RS
Offline F14CRAZY
« Reply #3 on: April 29, 2015, 10:21:29 AM »
I took the cheapest and easiest way out and installed a used K1200LT pump from ebay. Just make sure to get the other little oil pump gear that goes in the block due to the lower teeth count (in case anyone searches for this in the future, or if you're curious). I just wanted to get it back on the road. I saved my old pump in case I decide to eventually rebuild that. I think the issue was the pits tearing up the inner blue sealant of the new seal.
Will check the oil sump screen
  • Grand Rapids, MI
  • '87 K75C
Offline JcJ TN K75s
« Reply #4 on: April 29, 2015, 10:33:27 AM »
when you put the timing cover back on, remember that they are shoulder bolts. They bottom out. Torque them to the correct value (78 in/lb iirc). Any more an you might strip out the threads. IF you have an oil drip, its probably not your gasket leaking, but the little rubber dinguses on the shoulder bolts.  If they get old and hard, they don't transmit the correct squeeze pressure to keep the timing cover sealed.  I need to replace them on the Stormtrooper, it leaves a few drops on the floor after a few days.  I'll try to find you a part number sometime today, I need them anyway.
  • Lincoln, TN 37334
  • 1993 K75S? "Stormtrooper" 1999 R1100RTP "Lord Vader"
I am quite sure now that often, very often, in matters concerning religion and politics a man’s reasoning powers are not above the monkey’s.- Mark Twain
It could probably be shown by facts and figures that there is no distinctly native American criminal class except Congress.-
Mark Twain
Offline JcJ TN K75s
« Reply #5 on: May 04, 2015, 06:55:05 PM »
  • Lincoln, TN 37334
Mark Twain
Offline F14CRAZY
« Reply #6 on: May 04, 2015, 08:20:05 PM »
Those things seem to be holding fine on my bike but thanks for the part number. I might end up getting some anyway (a well sh!t, might as well thing)
  • Grand Rapids, MI
  • '87 K75C
« Reply #7 on: May 04, 2015, 10:43:56 PM »
It's more a sh!t -- don't want to have to do this twice thing. They're cheap. Skip lunch one day and get new ones.
Don't ask me how I know this. New gaskets might also be a good investment -- there's nothing worse than sealing those covers up and having to drain, pull and redo the whole thing. Well, there are worse things -- your recent thing with the water pump comes to mind. I admire your tenacity -- really, I do.
Offline zilla
« Reply #8 on: May 05, 2015, 07:34:28 AM »
I did this on my K100 a few weeks ago. Not that bad a job.
I used ultra grey to seal the pan.
Offline Idonthaveaclue
  • Veni, vidi, vici
« Reply #9 on: November 02, 2019, 12:33:53 PM »
Super old thread, but the closest I could find on my question.
I'm planning on re-sealing the timing cover. I was told that it holds the timing? I didn't see anything in the workshop manual about it?
Also I was told that the Timing cover is sealed with RTV. Is there a special kind?
Thx
  • Queen Creek, AZ
  • 87' K75S | 16' H-D Road Glide Special
1987 K75S
Offline alabrew
« Reply #10 on: November 02, 2019, 02:08:26 PM »
I put timing cover in the DuckDuckGo Search and found this: http://www.motobrick.com/index.php?topic=10205.0
  • Birmingham, Alabama
  • 1985 K100, 1991 K100RS
Also:
2005 K1200LT
1979 R65
Offline volador
  • NEEDS MORE CHROME
« Reply #11 on: November 02, 2019, 03:07:15 PM »
Engine gasket, cork, 11 14 1 460 307   $3.97
https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51711&rnd=07242017
If using 3-Bond instead its best to hand tighten bolts and let sit overnight to cure before final tightening
  • NYC NY
  • 1991 K100RS 1993 K75S ABS
Offline alabrew
« Reply #12 on: November 02, 2019, 04:15:53 PM »
That gasket is for the hall effect sensor, the cover doesn't have a gasket., I use Permex Form a Gasket.
Also:
2005 K1200LT
1979 R65
  • Veni, vidi, vici
« Reply #13 on: November 02, 2019, 06:05:18 PM »
Thanks for the reply.
Does the cover hold timing, or can I pull it off and not worry about that? (very new mechanic type here)
Thx
  • Queen Creek, AZ
1987 K75S
« Reply #14 on: November 02, 2019, 06:07:24 PM »
Does the cover hold timing . . .
No, it covers timing. :-)
  • 1995 K75 89,000 miles
