Author Topic: plug CA emissions hose to engine?  (Read 2918 times)
Offline REMA1000
« on: April 28, 2015, 12:53:47 AM »
On my 91 k100rs , the PO disconnected both the tank overflow, and the CA emissions hose.  I noticed that the hose (or at least, _a_ hose, which runs to the top of the engine, front edge, right under the fan) was just laying there, with the clamp still on it.  No sign of a 1-way valve, unless that's mounted to the engine.
I wondered if this hose should be plugged with a vacuum plug/golf tee?  Maybe it was, and the plug fell out.
Re: plug CA emissions hose to engine?
« Reply #1 on: April 28, 2015, 04:28:00 AM »
greetings rema1000...
please post up photos so we can see what you are seeing...
« Reply #2 on: April 28, 2015, 06:49:31 AM »
Yes, plug the hose.
I presume that a PO installed an accumulator cup under the fuel tank?
Offline K75RT Keith
« Reply #3 on: April 28, 2015, 05:48:34 PM »
You can hook it up but do you really want gasoline in your oil?
You can check the Liberry and find a number of posts on this hose and why to plug it.
1990 K75RT
