Author Topic: The BMU and LED tail light and brake lights  (Read 3636 times)
Offline Elipten
« on: March 31, 2015, 10:06:00 PM »
I cut pin 7 in the BMU to install LED turn signal lights.  Works great!
Now that pin 7 is cut can I also install and LED bulb for the tail light and brake light and not get the fault light on the instrument cluster?
If you use the Kisan SM-6 unit (which I have) can you then use LED lights for the tail light and brake light and not get the fault light on the instrument cluster?
Thanks all for the help in advance.
  • San Antonio, TX
  • 1990 K75RT
Re: The BMU and LED tail light and brake lights
« Reply #1 on: March 31, 2015, 10:21:03 PM »
Do you mean that you cut pin 7 on the IC in the flasher unit, not the BMU?
If you want LED tail lights and no warning on the dash, you'll have to remove the BMU altogether.  Remember that you are disabling a safety feature of the bike and it's not recommended.  Instructions for performing the mod is here:
http://classickbikes.com/ckb.tech/0.ckb.tech.files/bmu/bmu.htm
Offline Elipten
« Reply #2 on: March 31, 2015, 10:47:56 PM »
You are correct sorry for my confusion, it was the flasher unit, not the BMU.
  • San Antonio, TX
  • 1990 K75RT
