Author Topic: K1100rs Hall Effect Sensor replacement part # by Honeywell?  (Read 5354 times)
Offline Popetrout
  • I've been programmed not to be programmed.
« on: March 24, 2015, 09:53:15 AM »
Does anyone know the HES replacement part # from Honeywell that I could solder in?
Offline bmw-rider
Re: K1100rs Hall Effect Sensor replacement part # by Honeywell?
« Reply #1 on: March 24, 2015, 10:56:44 AM »
original 2AV24  Honeywell, or imitation CYHME56 from www.Chengyang.de
Offline Popetrout
« Reply #2 on: March 24, 2015, 12:04:07 PM »
thanks, do know of a good site to buy the whole hall effect sensor
at a discount? would like to avoid paying $4-500
Offline K75RT Keith
« Reply #4 on: March 25, 2015, 10:04:36 AM »
Somewhere in here is a contact for vane sensors and upgraded wires for the HES.  Seems that R1100's use the same units and have failures based on undersized wiring insulation. If you dig around you should find the post
1990 K75RT
Offline Popetrout
« Reply #5 on: March 30, 2015, 06:08:00 AM »
Much thanks!...would the CYHME56C be a better option since it has better resistance to magnetic interference?  any tricks to the switch out?  does my gremlin bell help prevent this type of thing happening again?
