Author Topic: Occasional Stall  (Read 4102 times)
Offline Snowman
  • Aberdeen SD.
Occasional Stall
« on: March 13, 2015, 09:38:05 AM »
This isn't a big deal but I thought I would throw it out to the wolves to chew on. '93 K1100LT, 121K miles, runs like a champ but very occasionally when coming to a stop it will try to stall in the last few feet. I can catch it, pull the clutch, blip the throttle a little and it settles into perfect idle. Anyone else experienced this?
Re: Occasional Stall
« Reply #1 on: March 13, 2015, 09:48:56 AM »
greetings snowman...
for me it was the 4pin fuel tank connector... every time i would stop it would die... i could give it a little whack and it would keep running...
after pulling the tank and messing with that 4pin it never did it again...
« Reply #2 on: March 13, 2015, 09:54:11 AM »
If messin with the electrical connector to the tank don't make any difference.....check the exhaust valve openings.
« Reply #3 on: March 13, 2015, 10:04:12 AM »
Howz yer air filter?
Offline Snowman
  • Aberdeen SD.
« Reply #4 on: March 13, 2015, 02:13:54 PM »
Air filter is good, it was doing it before I changed it last and now afterwards. It has been 13K since I did the valves and I'll check the connector first as that is the easiest, yeah, I'm beer drinking lazy. The temp is in the 70s here in SD!  :dunno! A sure sign of snow and freezing rain within the week. Going on a ride with the local  beemer chapter tomorrow, first ride of the year!  :riding: I think I'm the only Brick rider, lots of airheads and GS'ssssss
Thanks for the tips.
