Author Topic: DeOxit Rules!!!!  (Read 3712 times)
Offline Novafrk
DeOxit Rules!!!!
« on: March 01, 2015, 07:58:48 PM »
So my 88 K75S had a couple of instrument cluster issues. The tach didn't work, the neutral light didn't work, and the gear indicator didn't work.
I removed the cluster, and found light greyish corrosion on several areas along with a few burned out lights. I carefully hoses everything down with DeOxit purchased at my local Guitar Center. Radio Shack didn't have it. I had to let the components sit around for about a month. I doubt that had anything to do with it but it happened. I put it all back together tonight and everything works!!! Tach, Gear Indicator, Neutral light! I'm so stoked!!!!
88 K75S - My red headed mistress. Shhhh.
Offline mw074
Re: DeOxit Rules!!!!
« Reply #1 on: March 02, 2015, 08:10:07 AM »
You got lucky.
  • Michigan
Offline Novafrk
« Reply #2 on: March 02, 2015, 01:07:26 PM »
I suppose I did. Either way, I'm stoked it worked.
Offline kris
« Reply #3 on: March 02, 2015, 01:37:49 PM »
Nothing like small mechanical victories to put a smile on your face!!
"I got bike fever bad!!"
Offline Novafrk
« Reply #4 on: March 10, 2015, 01:52:05 PM »
Another follow up to the Deoxit story. I hadn't checked the high beam indicator when I did my test. It wasn't working. Upon further investigation, I did find 3 pins that were loose and had corrosion. They seem to have only been partially soldered. After carefully soldering them back to the trace, bingo! High beam indicator was functional. Still pretty lucky. ;-) Ready for the riding season!!!
