Author Topic: Temperature light flickering  (Read 59166 times)
Re: Temperature light flickering
« Reply #25 on: February 22, 2015, 05:32:44 PM »
That's the one, measure at the violet/green wire in female connector (which goes to the sensor) an ground.
Offline SeanK75
« Reply #26 on: February 22, 2015, 05:39:44 PM »
Ok when I'm getting 3.5 there when my black lead is on 31 (ground) in the relay socket if thats where it's supposed to go.
  • Vancouver BC
  • 1994 K75
« Reply #27 on: February 22, 2015, 05:43:59 PM »
Then do the same at the male part, the connection should be open.
Offline SeanK75
« Reply #28 on: February 22, 2015, 05:52:03 PM »
I'm getting no reading from the male pin to 31 on the relay.
  • Vancouver BC
  • 1994 K75
Offline SeanK75
« Reply #29 on: February 22, 2015, 05:55:26 PM »
What do you mean by the connection should be open? The sensor is plugged in, the engine/chassis and relay are not. Yhanks
  • Vancouver BC
  • 1994 K75
« Reply #30 on: February 22, 2015, 05:57:57 PM »
Then it looks normal, reconnect the chassis/engine connector and measure again between 31 and E in
the relay socket.
Offline SeanK75
« Reply #31 on: February 22, 2015, 06:01:46 PM »
Ok it reads 3.5.
  • Vancouver BC
  • 1994 K75
« Reply #32 on: February 22, 2015, 06:06:29 PM »
Try also to measure between 15 and A2 at the relay.
Offline SeanK75
« Reply #33 on: February 22, 2015, 06:06:48 PM »
So I seems like the temp sensor is fine. But when I turn the ignition on the fan still comes on. Can I trace it from the fan? What else could be signaling the fan? A fault maybe? Something that won't allow my bike to start. Any ideas? Horn and fan fuse seem to blow, maybe the circuits are touching somewhere because when I remove the horn fuse the fan doesn't run with the ignition.
  • Vancouver BC
  • 1994 K75
Offline SeanK75
« Reply #34 on: February 22, 2015, 06:13:42 PM »
1.5 between A2 and 15.
  • Vancouver BC
  • 1994 K75
« Reply #35 on: February 22, 2015, 06:17:18 PM »
And you measure on the terminals at the relay?....with the relay disconnected.
Offline SeanK75
« Reply #36 on: February 22, 2015, 06:19:44 PM »
Yes on the relay socket, A2(fan motor ) to 15(fuse #7)
  • Vancouver BC
  • 1994 K75
« Reply #37 on: February 22, 2015, 06:21:29 PM »
Not in the relay socket, but the relay itself.
Offline SeanK75
« Reply #38 on: February 22, 2015, 06:25:35 PM »
No reading from A2 to 15 on the relay. Only from 31 to E on the relay, 3.5
  • Vancouver BC
  • 1994 K75
« Reply #39 on: February 22, 2015, 06:34:15 PM »
This is normal, it was just to check that the contacts wasn't welded closed.
what a coincidence, same value as in the socket.
Offline SeanK75
« Reply #40 on: February 22, 2015, 06:36:18 PM »
I'm not sure what that means. Is 3.5 not normal for the relay?
  • Vancouver BC
  • 1994 K75
Offline SeanK75
« Reply #41 on: February 22, 2015, 06:38:32 PM »
Also reading 3.9 from 31 to 9 on the relay.
  • Vancouver BC
  • 1994 K75
« Reply #42 on: February 22, 2015, 06:49:03 PM »
No idea, as I never have needed to measure this connection.
Offline SeanK75
« Reply #43 on: February 22, 2015, 06:54:23 PM »
Well I REALLY appreciate your time. Thanks for your help. I'm stumped so I guess the next step is taking it in to my mechanic, unless you have any other ideas.
  • Vancouver BC
  • 1994 K75
« Reply #44 on: February 22, 2015, 07:00:55 PM »
Have you tried what I suggested earlier in this thread....with a temporary wire between 31 in the socket
and the battery negative terminal?
Offline SeanK75
« Reply #45 on: February 22, 2015, 07:04:32 PM »
I'll try now, sorry I missed that. I need to have the relay off to put the wire in, so what do I do once the wire is run?
  • Vancouver BC
  • 1994 K75
« Reply #46 on: February 22, 2015, 07:09:17 PM »
Twist the copper strands and push it up from the bottom of the socket so it makes contact with the
connector inside the socket, the relay must be present.
Offline SeanK75
« Reply #47 on: February 22, 2015, 07:14:36 PM »
Just tried and still the fan is on.
  • Vancouver BC
  • 1994 K75
« Reply #48 on: February 22, 2015, 07:16:40 PM »
Then I haven't any further ideas.
Offline SeanK75
« Reply #49 on: February 22, 2015, 07:19:14 PM »
I should mention that the ecu is still disconnected. Not sure that matters as the fan still comes on at ignition.
  • Vancouver BC
  • 1994 K75
