Author Topic: Temperature light flickering  (Read 74768 times)
Re: Temperature light flickering
« Reply #25 on: February 22, 2015, 05:32:44 PM »
That's the one, measure at the violet/green wire in female connector (which goes to the sensor) an ground.
SeanK75
« Reply #26 on: February 22, 2015, 05:39:44 PM »
Ok when I'm getting 3.5 there when my black lead is on 31 (ground) in the relay socket if thats where it's supposed to go.
« Reply #27 on: February 22, 2015, 05:43:59 PM »
Then do the same at the male part, the connection should be open.
SeanK75
« Reply #28 on: February 22, 2015, 05:52:03 PM »
I'm getting no reading from the male pin to 31 on the relay.
SeanK75
« Reply #29 on: February 22, 2015, 05:55:26 PM »
What do you mean by the connection should be open? The sensor is plugged in, the engine/chassis and relay are not. Yhanks
« Reply #30 on: February 22, 2015, 05:57:57 PM »
Then it looks normal, reconnect the chassis/engine connector and measure again between 31 and E in
the relay socket.
SeanK75
« Reply #31 on: February 22, 2015, 06:01:46 PM »
Ok it reads 3.5.
« Reply #32 on: February 22, 2015, 06:06:29 PM »
Try also to measure between 15 and A2 at the relay.
SeanK75
« Reply #33 on: February 22, 2015, 06:06:48 PM »
So I seems like the temp sensor is fine. But when I turn the ignition on the fan still comes on. Can I trace it from the fan? What else could be signaling the fan? A fault maybe? Something that won't allow my bike to start. Any ideas? Horn and fan fuse seem to blow, maybe the circuits are touching somewhere because when I remove the horn fuse the fan doesn't run with the ignition.
SeanK75
« Reply #34 on: February 22, 2015, 06:13:42 PM »
1.5 between A2 and 15.
« Reply #35 on: February 22, 2015, 06:17:18 PM »
And you measure on the terminals at the relay?....with the relay disconnected.
SeanK75
« Reply #36 on: February 22, 2015, 06:19:44 PM »
Yes on the relay socket, A2(fan motor ) to 15(fuse #7)
« Reply #37 on: February 22, 2015, 06:21:29 PM »
Not in the relay socket, but the relay itself.
SeanK75
« Reply #38 on: February 22, 2015, 06:25:35 PM »
No reading from A2 to 15 on the relay. Only from 31 to E on the relay, 3.5
« Reply #39 on: February 22, 2015, 06:34:15 PM »
This is normal, it was just to check that the contacts wasn't welded closed.
what a coincidence, same value as in the socket.
SeanK75
« Reply #40 on: February 22, 2015, 06:36:18 PM »
I'm not sure what that means. Is 3.5 not normal for the relay?
SeanK75
« Reply #41 on: February 22, 2015, 06:38:32 PM »
Also reading 3.9 from 31 to 9 on the relay.
« Reply #42 on: February 22, 2015, 06:49:03 PM »
No idea, as I never have needed to measure this connection.
SeanK75
« Reply #43 on: February 22, 2015, 06:54:23 PM »
Well I REALLY appreciate your time. Thanks for your help. I'm stumped so I guess the next step is taking it in to my mechanic, unless you have any other ideas.
« Reply #44 on: February 22, 2015, 07:00:55 PM »
Have you tried what I suggested earlier in this thread....with a temporary wire between 31 in the socket
and the battery negative terminal?
SeanK75
« Reply #45 on: February 22, 2015, 07:04:32 PM »
I'll try now, sorry I missed that. I need to have the relay off to put the wire in, so what do I do once the wire is run?
« Reply #46 on: February 22, 2015, 07:09:17 PM »
Twist the copper strands and push it up from the bottom of the socket so it makes contact with the
connector inside the socket, the relay must be present.
SeanK75
« Reply #47 on: February 22, 2015, 07:14:36 PM »
Just tried and still the fan is on.
« Reply #48 on: February 22, 2015, 07:16:40 PM »
Then I haven't any further ideas.
SeanK75
« Reply #49 on: February 22, 2015, 07:19:14 PM »
I should mention that the ecu is still disconnected. Not sure that matters as the fan still comes on at ignition.
