K75........misfiring and no idle
Topic: K75........misfiring and no idle (Read 4272 times)
keith g
Motobrick Curious
January 27, 2015, 12:02:16 PM »
it started to misfire just before christmas put new plugs and wires on her but the problem is still there........i'm open to suggestions as to what may be the cause.....!!
UK
1985 K75c
TimTyler
Adrninistrator
Re: K75........misfiring and no idle
Reply #1 on:
January 27, 2015, 12:09:30 PM »
My money is on "air leak".
keith g
Motobrick Curious
Reply #2 on:
January 28, 2015, 05:23:25 AM »
i was hoping it would be simpler than that....:)
but it is an '87 model and all original.......the inlet rubbers are def past there best......oh well......in the garage...pull her to bits...:(
UK
1985 K75c
Inge K.
Reply #3 on:
January 28, 2015, 05:37:40 AM »
Start With checking the crank ventilation hose......S shaped, at the rear end of the plenum chamber.
They have a rather short average lifetime.............
Norway
TimTyler
Adrninistrator
Reply #4 on:
January 28, 2015, 11:41:21 AM »
What Inge said.
Air leaks aren't necessarily expensive or hard to fix, and they can be easy to find with a spritz of carb cleaner.
You could also try replacing your fuel filter which might be clogged and you could check to see if there's a bunch of mice living in the airbox.
keith g
Motobrick Curious
Reply #5 on:
March 15, 2015, 05:10:29 PM »
Tim.......you were right.......airleak.......when i took the throttle bodies off,the centre inlet stub came with it...!!!,all new rubbers fitted,runs better than ever...!
UK
1985 K75c
