Author Topic: K75 smokes in a mysterious way (not right on startup)  (Read 4093 times)
mossy173
« on: January 16, 2015, 09:40:51 PM »
Well, I could definitely use some help with a mysterious problem.
What I have is a 1987 K75C I've recently acquired as a fix-up project that exhibits a very strange pattern of smoking--it doesn't make the puff on startup that the bike is known for, but rather starts up smoke-free and after around thirty seconds or so starts to smoke badly.  Makes me think that it isn't an issue of oil seeping past the rings (it's on the centerstand).  The smoke is bluish.  If I let it sit ten minutes and start it again, it's smoke-free for the better part of a minute once more.
The bike has 65k miles, and compression seems to be excellent: 190, 190, 185 psi.  I recently went through the intake and replaced the rubber boots between the plenum and the throttle bodies as well as the crankcase breather hose.  When I did, I found that the air filter was completely soaked in oil, and oil was being sucked down into the intake.  I thought I had found the cause of my smoking, but cleaning it all out hasn't stopped it.  In fact, aside from some severe stumbling off idle that I've improved with the new rubbers, the bike runs about exactly as it did when I first got it.
I was thinking I might have bad valve stem seals.  I'm really not too sure what to make of it.  Any thoughts?  I'm happy to provide any other info that might be illuminating.
Re: K75 smokes in a mysterious way (not right on startup)
« Reply #1 on: January 19, 2015, 09:17:02 PM »
Did you figure out why the air filter was oiled? That's not good...sounds more like a symptom than a cause.
« Reply #2 on: January 19, 2015, 09:29:08 PM »
my guess would be ring blowby forcing oil up through the pvc hose.  Could have been a stuck piston ring, change that air filter and if it gets oiled again maybe add a quart of Rinsoline in the crankcase.
mossy173
« Reply #3 on: January 21, 2015, 03:40:27 PM »
I hadn't thought of that.  Ok, here's what I'll do: new valve stem seals, then put it back together and test; if it's still smoking I'll try to go after the piston rings with some kind of solvent.  I couldn't find any info on rinsoline, but I've used seafoam before to good effect.
