Author Topic: Odometer repair  (Read 16489 times)
Offline Bokobob
  • I am a 1936 Model
Odometer repair
« on: December 20, 2014, 03:23:19 PM »
1987 k75 with odometer that stopped working.....
Found a company in Texas named
Overseas Speedometer..
If you have any feedback on this firm, please reply with your comment or opinion..
Thank you
  • Gastonia, NC
Grace + Peace,
Bob
1995 BMW K75
1994 Honda Magna 750 V4
1996 Kawasaki Vulcan 500
Offline Elipten
Re: Odometer repair
« Reply #1 on: December 20, 2014, 04:12:17 PM »
Nice man, knows his stuff.  Did a great job.  Well reviewed on this site and others.  While in there consider putting in Frankenduck LED conversion, which Overseas can do for you.
  • San Antonio, TX
  • 1990 K75RT
Offline Bokobob
  • I am a 1936 Model
Re: Odometer repair
« Reply #2 on: December 21, 2014, 10:11:11 AM »
Thank you for the testimonial...I'll start to dismantle it and get it sent off..
  • Gastonia, NC
Grace + Peace,
Bob
1995 BMW K75
Offline Elipten
Re: Odometer repair
« Reply #3 on: December 21, 2014, 10:49:29 PM »
He only repairs on Friday at his lake house.  So don't expect 1 day turnaround or anything like that.  Been there in person, plenty of parts, knows his stuff.
  • San Antonio, TX
  • 1990 K75RT
Offline detbmw
Re: Odometer repair
« Reply #4 on: February 17, 2015, 06:59:01 AM »
I used him in 2012, did an excellent job. My speedo is within 1 mph of my gps.
  • Nacogdoches, Texas
Rich
Re: Odometer repair
« Reply #5 on: February 17, 2015, 08:14:01 AM »
If your speedo is working, but not your odo, it could just be that the gears are stripped in the odometer (not unusual).
If you're not afraid to get in there and take things apart, you can buy a replacement from MAXBMW for about $110.
Part number     62 11 2 305 175
http://www.maxbmwmotorcycles.com/fiche/NotesParts/62112305175_1_B.jpg
Offline detbmw
Re: Odometer repair
« Reply #6 on: February 17, 2015, 11:32:47 AM »
I found that my speedometer usually would work intermittently after I removed the FD to lube the pinon splines. The speedo/odometer would quit for a while, then work, then quit for a while. I put a very small dab of bulb grease on the two pins of the speedo wire connector under the right-side battery cover. The speedo immediately started working again and I've never had that problem since.
It's good maintenance to do anyway, and it helps the pins to make a good connection (since the speedo uses wiring instead of a cable).
Rich
Re: Odometer repair
« Reply #7 on: February 17, 2015, 12:09:42 PM »
Bulb grease and dielectric grease are non-conductive. The help seal out moisture and lube plastic connectors, but I don't understand how they could improve electrical connections.
Re: Odometer repair
« Reply #8 on: February 17, 2015, 02:08:01 PM »
They prevent corrosion. The contacts press through the grease, and make contact with each other. The silicone prevents corrosion from forming in those spots.
Offline bocutter Ed
Re: Odometer repair
« Reply #9 on: February 17, 2015, 03:19:51 PM »
also prevents arcing in switches & relays.
  • Toronto, Canada
Re: Odometer repair
« Reply #10 on: February 17, 2015, 03:28:50 PM »
Copy that! Thx.
Re: Odometer repair
« Reply #11 on: February 17, 2015, 03:42:53 PM »
The best procedure for electrical connections is a shot of WD-40 or PB-blaster to remove corrosion, followed by dielectric grease. Worth doing to all connections on your brick as preventative maintenance.
Offline enb54
Re: Odometer repair
« Reply #12 on: February 20, 2015, 12:18:01 AM »
I'll 3rd that, more problems with electrical connections solved on all machines by ensuring good clean connections followed by the application of dielectric grease, especially the problematic speedometer connection...
  • Red Deer, AB
Eric
Offline Bokobob
  • I am a 1936 Model
Re: Odometer repair
« Reply #13 on: March 14, 2015, 01:13:53 PM »
Got the unit back and it cost $200 plus two way freight of total of $75....Well pleased with how it works now....have not compared speedo calibration vs gps as I don't ahve that setup.
Oh yes, and I did use Overseas Speedometer in Austin TX to do the work..very satisfied...
  • Gastonia, NC
Grace + Peace,
Bob
1995 BMW K75
Offline bakio
Re: Odometer repair
« Reply #14 on: July 22, 2018, 03:39:13 PM »
My odometer just died on a 94 K75, and I'm going to send it to Texas. Any things to watch for or hints for pulling the panel?
  • San Carlos
  • K75, R65, XL250
