Author Topic: k11 backfire  (Read 4404 times)
Offline gazman
k11 backfire
« on: December 09, 2014, 06:12:59 PM »
greetings, Ive found that if riding with lots of throttle and then back off fast she will backfire, doesnt happen if I back off slowly. changed the plugs, no differance,ordered a carbtune so will sink throttle bodies soon. Any ideas?
  • west australia
  • 93 K1100LT
Offline Inge K.
Re: k11 backfire
« Reply #1 on: December 09, 2014, 06:28:01 PM »
Check for broken weld(s) at the ekshaust collector.
Also check the rubber mountings, especially the one under the gearbox......worn, broken mountings is often
the reason to broken welds at the ekshaust collector.
  • Norway
Offline gazman
Re: k11 backfire
« Reply #2 on: December 09, 2014, 07:43:40 PM »
changed that lower mount about a month ago, old one was broken. just checked for exhaust leaks at collector with hose to the ear and BINGO she,s leaking. I,m thinking take it off and mig weld it, or is there a better method? thanks  :riding:
  • west australia
  • 93 K1100LT
Offline Inge K.
Re: k11 backfire
« Reply #3 on: December 09, 2014, 07:57:53 PM »
Tig won't crack that easily between the weld and material, and you reach a bit better into those tight Places.
  • Norway
Offline gazman
Re: k11 backfire
« Reply #4 on: December 09, 2014, 09:31:26 PM »
Thanks Inge TIG it is :2thumbup:
  • west australia
  • 93 K1100LT
Offline Grim
Re: k11 backfire
« Reply #5 on: December 11, 2014, 10:00:45 PM »
Also pull the throttle bodies if that doesnt fix it. The boots (BMW calls them bushing) are proned to failing with age. It's likely yours are due if original.
1995 Morea Green K1100LT
