Author Topic: K75S Forks: Progressive Springs vs Cartridge Emulators?  (Read 9923 times)
Offline Lucas
« on: December 07, 2014, 11:25:19 PM »
So today I put on a Progressive shock and it was a definite improvement over my stock shock, my forks feel a bit squishy in comparison. So I'd like some advice what kind of improvements there are.
I have a 1992 K75S. I did the fork oil about 9 months ago, and that helped a bit.
I've read that these already have progressive springs? Is this true?
If the Cartridge Emulators are a good mod, how hard are they to install? I don't have a workshop or garage, so is there drilling involved or are they drop ins?
Basically, whats the best price/performance ratio?
Offline Brad-Man
Re: K75S Forks: Progressive Springs vs Cartridge Emulators?
« Reply #1 on: December 08, 2014, 03:42:30 PM »
I haven't done emulators yet, but be aware that almost anyone who knows about them say they should be used with single rate springs - not progressive.
  • Marietta, GA
  • '85 K100
'74 RD350
Offline mjydrafter
« Reply #2 on: December 09, 2014, 06:55:03 AM »
It's not too difficult to pull the springs and have a look.
I recently upgraded from stock springs to Progressives and I am very happy that I did.
I don't know too much about the emulators.  I had a KLR and guys were always doing them on those, but I'm not sure the KLR fork is even as nice as a stock K-fork.  I know they are different beasts, but to a point a fork is a fork.
There is a lot of feedback on the progressive springs. I don't think I found any negative remarks.
1986 BMW K75c
« Reply #3 on: December 09, 2014, 07:46:53 AM »
Another option would be a little heavier oil to stiffen up the forks.
The stock wt is 7.5, I have read of quite a few that have gone to 10wt or a little higher.
At least it is something fairly simple and inexpensive to try.
Offline TaosBob101
« Reply #4 on: December 09, 2014, 11:59:11 AM »
 I'm putting a Progressive Spring set in Sat. My BMW tech friend is going to use 10wt .
  • Jefferson County, Colorado
  • 1995 K75S
1995 K75S
Offline subforry
« Reply #5 on: December 09, 2014, 01:05:32 PM »
The "guts" of my K1100 forks look pretty complex.  Not sure that cartridge emulators would do much over stock, also I expect there would be hacking and fabrication involved.
Springs don't cost much compared to the benefit.  Get some springs that match your weight.  Dropping them in from the top with the forks in place is easy.
I have Race Tech springs.  Very happy.
  • Hermosa Beach, CA, USA
  • 1996 K1100RS
1981 Suzuki GS850G
1990 Suzuki Katana 1100 (GSX1100F) - sold
1996 BMW K1100RS
2009 BMW K1300GT
« Reply #6 on: December 09, 2014, 01:59:59 PM »
Your RS allready have a cartridge fork.
Offline Brad-Man
« Reply #7 on: January 14, 2015, 11:29:33 PM »
Hey Inge:
I was looking @ the 'fiche on Max's BMW site and the K75S and early (2V) K100's seem to have the same (damper rod) suspension while the 4v/1100 seem to have cartridge types - if I'm understanding what I see.  I'e never seen a cartridge type fork broken down...
Can you verify what was in each model?
I've heard that for my K100 2v that going to the 4v/1100 front end would net me progressive springs - which kinda goes against current thinking of using linear springs w/emulators/cartridges - if in fact they DO have cartridges.  But if BMW did it I'm sure it's well thought out...
  • Marietta, GA
  • '85 K100
'74 RD350
« Reply #8 on: January 15, 2015, 02:21:26 PM »
Beside the K11's also K100RS16V and K1 did get the cartridge fork late in their production lifetime.
About the combination cartridges/progressive springs I would guess that Marzocchi (who made the fork)
also know what they're doing after more than 50 years of fork production.
Offline Brad-Man
« Reply #9 on: January 15, 2015, 08:25:04 PM »
Thanks for verifiying what I thought I saw Inge!
Since I have the 4v front end that I will be adding to my '85, I should only probably have to mess w/oil weight when freshening for my weight.
No spring no emulator purchase - I'm in heaven!
  • Marietta, GA
  • '85 K100
'74 RD350
« Reply #10 on: January 15, 2015, 11:06:35 PM »
If it from a K11 or a late K1/K100RS16V and have a 12 mm oil filler plugg it's a cartridge fork, early 4V
Marzocchis is traditional damper rod fork, and have a 10 mm oil filler plug.
The cartridge version have different oil capacities L/R (if only drained) 350/400 cc.
If you have a complete front end (wheel, brakes, triples), you would also need a 20 mm master, that is a
different throttle assy...you must mod the throttle cable.
Offline Brad-Man
« Reply #11 on: January 16, 2015, 08:45:15 PM »
I have non-BMW controls on the bike and the lever doesn't move much - good thing I have a good grip.
Bought it this way, si I'm thinking I have a master cylinder for a bike w/4pot brakes already...
I'll check out the forks the next time I'm rummaging in the garage.
Thx...
  • Marietta, GA
  • '85 K100
'74 RD350
