Author Topic: SMALLER WHEELS WANTED FOR A DIESEL BMW K100  (Read 7111 times)
jimmy62alan
« on: November 11, 2014, 10:49:48 AM »
Has anyone got any any ideas which BMW K100 used the 16" wheels I seen a listing stating the RS model used 16" front wheel but it did not mention what size rear wheel was use. If anyone can give me feed back on the 16" BMW I will be very grateful as I'm building a diesel BMW K100 bike and want to lower the centre of gravity to make it handle better.
Cheers ALAN
Sheffield S25
Ps Im starting the build with a BMW K100 frame so it will be a build with patients lol
Offline Dennis de Vries
Re: SMALLER WHEELS WANTED FOR A DIESEL BMW K100
« Reply #1 on: November 11, 2014, 02:44:46 PM »
Never heard of BMW using a 16 inch wheel on a K, but i think i remember the R1200C having a 15 inch wheel. Maybe that'll fit?
  • Holland, Europe
  • '89 K75RT
Offline pdg
« Reply #2 on: January 02, 2015, 04:11:56 PM »
As you only have a single post that was some time ago this will probably be academic, but hey...
First off, 'most' 16" rear tyres are fairly tall (like 15" tyres, aimed at flabby cruisers) and you actually end up having it 'bigger' than a more modern 17" would be.
But, let's say you find a nice low profile 16" tyre and manage to drop the back end by an inch or two - here is what will happen:
The handling will not be improved by 'lowering the centre of gravity' - this is a bike, not a car. It'll handle like shit (or like a harley, but those words are interchangable anyway). You might think you can drop the front end to compensate (smaller front wheel/dropping the yokes down over the forks) but it won't compensate at all - a smaller front wheel will make it twitchy and the change in trail will make it wallowy. Yes, it'll be twitchy and wallowy at the same time.
So, let's say that is what you want - a bike that is only rideable up to about 35mph.
Good, because the gearing (exacerbated by the smaller wheel) will mean you are hitting the diesel engine's rev limiter at about 38mph in top. Unless you happen to have a diesel engine that will be able to pull more than 5krpm and be comfortable while doing it?
Now, what I said up there about the handling - that is not a "BMW knows best" rant. I got a rear shock off ebay that turned up and was about 1.25" shorter than stock. It did not go well.... No amount of fiddling would get it to ride right - until I made up a set of brackets to lift the back end again. My bike now sits aroundabout 1.5" higher than stock front and rear and imo is much better for it (on and off the roads here).
I am more than happy to expand on anything I said if anyone is interested.
1988 K75S
Offline Grim
« Reply #3 on: January 03, 2015, 08:43:27 AM »
Low reving deisel I would think gearing wise smaller wheel would be an issue that most conversions would want larger and the LT hwy gear.
1995 Morea Green K1100LT
