The MBdotCOM Community Center
Only 85 More Years to Use Your K-Bike
Topic: Only 85 More Years to Use Your K-Bike (Read 4855 times)
TimTyler
Adrninistrator
November 02, 2014, 11:16:08 AM »
Fossil fuels should be phased out by 2100 says IPCC
http://www.bbc.com/news/science-environment-29855884
:riding:
Get riding!
:riding:
johnny
TrailBrakingThrottleWhacker
Re: Only 85 More Years to Use Your K-Bike
Reply #1 on:
November 02, 2014, 12:22:36 PM »
i have already converted to cannagas... by product of refining cannaboil...
its 35 degrees and sunny... going for ride... ha ha ha...
wmax351
Reply #2 on:
November 03, 2014, 04:25:15 PM »
Convert them to run on ethanol. By then we should have figured out cellulosic ethanol production, which eliminates the issues and inefficiencies of using corn to produce it.
http://www.wolframalpha.com/input/?i=%28133+cc%2Fminute+*+.76+g%2F+cm%5E3+*+14.7%2F9%29+%2F++%28.79+g%2Fcm%5E3%29
All that would be required is to use ethanol proof fuel hose, pump damper, and a 209 cc/minute injectors/pressure reg setup, rather than our 133 cc/minute @ 35 psi ones. Put a normal 43.5 psi regulator in, and some standard 20 pound an hour injectors, and you're golden. While you're at it, you could bump the compression ratio and timing a bit. Would give more power, beyond the increase already there from the ethanol.
Albuquerque, NM
91 BMW K75 Standard, 98 Moto Guzzi California EV
Photog
^ Proficient Motobricker
Reply #3 on:
November 03, 2014, 05:29:38 PM »
I guess that will be as good a reason as any to give up riding the motobrick when I'm 145.
NNE
K75-S
Brad-Man
Reply #4 on:
November 03, 2014, 10:12:43 PM »
Then triple the size of the gas tank....
Marietta, GA
'85 K100
'74 RD350
